Lanyard tube Para 3 (Aftermarket easier?)
I've been looking into titanium hardware for the Para 3 and was wondering...Once I get the factory lanyard tube out is it easier to assemble/disasemble the knife with a titanium lanyard tube in place?
E|D|C
Cold Steel Tuff-Lite
Case XX 5finn Fixed Blade
LetmY 18650/UV395/1kLm Flashlight
Re: Lanyard tube Para 3 (Aftermarket easier?)
It is if you get a lanyard plug instead of a tube
So do i need a tool to remove the original tube to replace with a plug? I'm trying to avoid that.
E|D|C
Your hands should be able to pry the handles apart. You can also use soft jawed pliers to remove the lanyard tube or pliers with a folded mousepad between the jaws
The lanyard plug isn’t pressfit like the tube. It just sits in the holes.
Oh nice! Are the aftermarket (flytanium) lanyard tubes like that too?
E|D|C
Sorry I’ve never owned one of those
Does the stock lanyard tube fit into titanium scales, or do I need aftermarket? I know the OEM lanyard tube can be a tad difficult to remove from G10 but once it's out can it be used in titanium scales and removed easily for cleaning etc.
E|D|C
Yes it fits
