Automony 2 Rusted
Sharkfisher51
Automony 2 Rusted
Post by Sharkfisher51 »
So....
After this "wonderful shutdown" I've been able to test both the Autonomy 2 and the Spydiechef but for this review I'll focus on the Autonomy 2. For the last 3 months since the middle of March, this knife has been in the gulf of Mexico shark fishing off the surf for about 4 hours a day every single day in my shorts pocket. I've noticed rust around the blade lock switch but other than that the knife is smooth as greased lightning. I'm not sure what is going on but it's supposed to be for the U.S. Coast Guard. It's not going to work for them if this is the long term goals. The knife was good for the first two weeks but now it's rusted and will not lock with the safety. It's sharp and a wonderful knife otherwise. The best Spyderco I own.
rust 4.PNG (150.44 KiB) Viewed 3058 times
Re: Automony 2 Rusted
H Sharkfisher,
Welcome to our forum.
Can you give me more input as to where the rust is? Can we get the knife back and send you a new one for R & D.
tbdoc4kids
Post by tbdoc4kids »
I thought the CG version did not have a safety lock.
VooDooChild
Post by VooDooChild »
Dang... not good.
Wonder if its liners, or the spring, or...
Did rust ever come back on your spydiechef after cleaning the initial rust from surface contamination?
I'm pretty sure this model has nothing to do with the Coat Guard....just sayin. The Autonomy 1 was the CG knife and even that is only the orange one without the lock.
It needs sent back to Golden. This is the sort of thing that needs professional evaluation, it's an opportunity to improve something.
curlyhairedboy
Post by curlyhairedboy »
Interested to see what the culprit on this model is. I know there's some ongoing CQI on the salt models. Maybe dlc on the lock slide?
RamZar
Post by RamZar »
The CG-approved Autonomy does not have the manual safety where the OP's Autonomy 2 corroded. The general public Autonomy 1 also have the safety. The Black DLC Autonomy 1 may not be prone to such corrosion due to the coating.
The SMKW exclusive Autonomy 2 looks like it has all the screws, safety and button in Black DLC coating but unfortunately the blade is S30V not LC200N.
Autonomy Coast Guard - Orange G-10 H-1 Satin Blade (no safety)
Autonomy 1 - Orange G-10 H-1 Satin Blade (safety)
Autonomy 1 - Black G-10 H-1 Black DLC Blade & Hardware (safety)
Autonomy 2 - Black G-10 LC200N Satin Blade (safety)
Autonomy 2 - SMKW Exclusive Carbon Fiber S30V Satin Blade Black DLC Hardware (safety)
Rinzler
Post by Rinzler »
I wonder where that rust is coming from. It's all over the flat surface of the lock and all around the inside lock opening of the G10.
Picture shamelessly stolen from barman1 on bladeforum.
And what's with the "upgraded" S30V on the exclusive? Not my first or even last choice. I own nothing anymore in S30V.
Sharkfisher51
sal wrote:
Sun Jul 12, 2020 8:39 pm
H Sharkfisher,
Hi Sal,
The rust appears to be under the thumb lock. It's almost completely frozen up and you really have to press on it hard to get it to move. The rest of the knife is beautiful and show's no sign of rust or corrosion of any kind. I don't know if there's a non SS steel detent ball or the like which is the culprit. I'm a huge fan of the LC200N steel and it's great for the salt. I'd be happy to send it back for investigation and what the failure mode is.
Thanks
Sharkfisher51
VooDooChild wrote:
Mon Jul 13, 2020 12:27 am
Dang... not good.
You remembered my Spydiechef! The rust/staining never progressed on the blade further than what I initially found. I'll add to the thread when I have the chance but all around the hardware is now rusting on the Spydiechef. I'm guessing it's the black oxide screws? Stay tuned...
gbcaffee
Post by gbcaffee »
All I can think of when I read this thread title:
https://youtu.be/PmfnsVCYB_E
Hi Sharkfisher,
Thanx for the input. Would you try to put some rust inhibiting or rust removal into the lock area and get back tome?> We'll look into it our our end.
Sharkfisher51
sal wrote:
Tue Jul 14, 2020 12:23 pm
Hi Sharkfisher,
Here's what she looks like opened up. I removed all the rust from the liner with a Q tip and some methanol and it came right up. No pitting. It appears to be the slide lock that is rusting.
Rinzler
Post by Rinzler »
It's odd that the raised button on the lock isn't showing oxidized. Maybe it's the detent ball???
Sharkfisher51
Rinzler wrote:
Tue Jul 14, 2020 2:33 pm
I know, I found that odd as well. The button is shaped like the hats Devo wore in "Whip it" lol... I'm not sure if those are two different metals? Also the detent ball looked great after the cleaning, no pitting and it was nice and shiny. The underside of the slide lock is also a corrosive mess. I'm working on getting that pic uploaded too. Could it be that small stainless particulates are generated when moving the slide back and forth that those are tiny enough to oxidize?
Hi Sharkfisher,
Thanx for the close input. I'll get that information to manufacturing. Let me know what you want to do. I can replace the knife, but the lock will be the same on all of them. We've not had this problem yet. Maybe it the time spent wet?
Sharkfisher51
sal wrote:
Tue Jul 14, 2020 3:53 pm
Hi Sharkfisher,
Hi Sal,
Thanks for prompt response. If you could replace the knife that would be great. I understand that it will have the same parts and materials and this could happen again. Maybe in the future if you implement design changes to it you could let me know so I could test it out? What do you need from me for a replacement? I'd be more than happy to send this back for failure analysis.
Surfingringo
Post by Surfingringo »
Thanks for the solid feedback Sharkfisher. And thanks for the prompt response Sal. This is how products evolve and improve!
RamZar
Post by RamZar »
I wonder if you replace the slide lock bar on Autonomy 2 with a DLC one like on Autonomy 1 DLC (and possible SMKW Autonomy 2) would prevent this rusting issue.
Sharkfisher51
Surfingringo wrote:
Tue Jul 14, 2020 4:28 pm
Just to be clear, this is one **** of a knife! If it didn't have the blade lock that rusted it's knife perfection at it's finest. This is definitely a SHTF knife and still opens and closes like a champ. The LC200N steel is really the holy grail of knife steels and in an automatic package makes this the holy grail of folders IMO. I also have the Spydiechef which has some rust around the assembly hardware but it's a great knife too, no blade rust. I really put these knives to the test in the saltwater, cutting bait/bones/150lb braid/, dropping in the sand etc... Any other knife besides the salt series knives wouldn't last a day doing the stuff I do to these two knives with LC200N. It's really a testament to Spyderco and the quality of these folders to take this marine environment day in and day out.
It's funny, I've bought two "dragon fly 2" H1 knives as gifts and never one for myself so I can't say how the H1 steel compares to LC200N. Maybe that will be my next purchase as a control test. I've just read how soft the H1 is and steered away from it.
