Rust preventative ?
TheRaven
Rust preventative ?
Post by TheRaven »
So I did a search on rust prevention for high carbon blades, and found a ton of information...too much information in a way.
If someone wants a good high carbon rust preventer...
1) food safe (won’t go bad)
2) dry (not oily or sticky)
What are people using these days?
Thanks
Naperville
Re: Rust preventative ?
Post by Naperville »
The museums all around the world coat armor and blades in WAX. I asked a bladesmith who made me a custom knife what to use and he said Renaissance Wax. I doubt that it is food safe, but there must be a wax that is and that would be your best bet.
Manufacturers of knives that are pumped out will recommend motor oil.
Post by The Deacon »
If you want to go with wax, paraffin would be a good bet. Fairly inexpensive, easy to find, and one of its uses is to seal the tops of jars used for home canning, so it has to be food safe.
