The Endela.
Fright_Fox
The Endela.
I’m thinking about getting an Endela for destroying boxes at work, do you guys like this model or should I just get another Endura (traded my last one). Thanks.
Re: The Endela.
The Endela has a slightly improved handle for some compared to the Endura (a bit more handfilling, the points between the finger grooves have been mellowed out).Fright_Fox wrote: ↑Wed Dec 11, 2019 5:02 pmI’m thinking about getting an Endela for destroying boxes at work, do you guys like this model or should I just get another Endura (traded my last one). Thanks.
The really great thing about the Endela: You can get it in SE ffg (not sabre grind like the Endura SE).
I'd STRONGLY recommend the serrated Endela, it's an amazing cutter with it's rather shallow, not too aggressive serrations.
Feels more like an "improved plain edge" .
Get one (in SE!!), you won't regret it!!
Re: The Endela.
Another "yes" on the SE Endela. The SE Jazzelica is another good choice for turning boxes into small pieces of cardboard.
Re: The Endela.
And the PE Delica wharnie cuts boxes all day too. All good choices.
- best wishes, Jazz.
Re: The Endela.
SE Endela, absolutely amazing cutter. Very well balanced in size.
spyderwolf
Re: The Endela.
The Endela was the second knife i bought thinking i will absolutelly love it.The first one was the Yojimbo,by the way.Turns out i like the Endela,but i not LOVE it.I carry it,used it,and turned back to my beloved Delica.For your cutting needs,i think a wharnie Delica will be better.PE or SE.
Whenever there is any doubt, there is no doubt.
Re: The Endela.
:D I knew you’d be on this like a duck on a June bug, as we say. :DWartstein wrote: ↑Wed Dec 11, 2019 5:11 pmThe Endela has a slightly improved handle for some compared to the Endura (a bit more handfilling, the points between the finger grooves have been mellowed out).Fright_Fox wrote: ↑Wed Dec 11, 2019 5:02 pmI’m thinking about getting an Endela for destroying boxes at work, do you guys like this model or should I just get another Endura (traded my last one). Thanks.
I keep putting one in my cart and thenSpyderco releases something else that I need. One of these days...
Re: The Endela.
I just HAD to :o ... the serrated Endela IS that good. Amazing cutter! Though if one is ok with the shorter cutting edge, I imagine the Wharnie SE Delica is at least as good or even better (never tried one myself)Doc Dan wrote: ↑Thu Dec 12, 2019 8:04 am:D I knew you’d be on this like a duck on a June bug, as we say. :DWartstein wrote: ↑Wed Dec 11, 2019 5:11 pmThe Endela has a slightly improved handle for some compared to the Endura (a bit more handfilling, the points between the finger grooves have been mellowed out).Fright_Fox wrote: ↑Wed Dec 11, 2019 5:02 pmI’m thinking about getting an Endela for destroying boxes at work, do you guys like this model or should I just get another Endura (traded my last one). Thanks.
Re: The Endela.
I've been eyeballing the SE Endura wharnie lately. I wonder if the Endela will eventually get a wharnie blade too?
Re: The Endela.
The Endela blade has a size in which I´d only just like a wharnie, while the Endura is too long for that for my liking (don´t like wharnie style in longer blades for some reason).
I on the other hand wonder, if the Endura will eventually get the SE treatment in ffg and its regular (not wharnie) blade...
Re: The Endela.
Wartstein wrote: ↑Thu Dec 12, 2019 8:26 amThe Endela blade has a size in which I´d only just like a wharnie, while the Endura is too long for that for my liking (don´t like wharnie style in longer blades for some reason).
I thought it already did. I wonder if there's a Delica/Endura 5 coming with an updated handle shape like the Endela.
Re: The Endela.
Unfortunately not... the SE Endura and Delica (other than the Wharnie) are still in sabre grind.Evil D wrote: ↑Thu Dec 12, 2019 8:38 amWartstein wrote: ↑Thu Dec 12, 2019 8:26 amThe Endela blade has a size in which I´d only just like a wharnie, while the Endura is too long for that for my liking (don´t like wharnie style in longer blades for some reason).
Re: The Endela.
Which is a terrible shame, especially for the endura :-DWartstein wrote: ↑Thu Dec 12, 2019 8:55 amUnfortunately not... the SE Endura and Delica (other than the Wharnie) are still in sabre grind.Evil D wrote: ↑Thu Dec 12, 2019 8:38 amWartstein wrote: ↑Thu Dec 12, 2019 8:26 amThe Endela blade has a size in which I´d only just like a wharnie, while the Endura is too long for that for my liking (don´t like wharnie style in longer blades for some reason).
I thought it already did. I wonder if there's a Delica/Endura 5 coming with an updated handle shape like the Endela.![]()
Re: The Endela.
+1geronm042 wrote: ↑Thu Dec 12, 2019 9:38 amWhich is a terrible shame, especially for the endura :-DWartstein wrote: ↑Thu Dec 12, 2019 8:55 amUnfortunately not... the SE Endura and Delica (other than the Wharnie) are still in sabre grind.Evil D wrote: ↑Thu Dec 12, 2019 8:38 amWartstein wrote: ↑Thu Dec 12, 2019 8:26 am
- jasonstone20
Re: The Endela.
I don't have an Endela, but I have been thinking of getting one, or maybe a Stretch (The staight spine Stretch really has my attention, I wish it was in Super Blue, V-Toku 2, 52100, or AEB-L. I do like VG10, that whole class of steels is great for EDC). I have the Delica/Endura clone from Benchmade, the Pika II (G10, Purlple titanium liners, Harley Davidson line) along with a Byrd Meadowlark 2 Hawkbill. If you are getting a knife just to cut boxes, I would get either the Wharncliff Delica or Endura, and if you don't like sharpening I would get a full SE. For a knife you are going to use for EDC also, I would get the Endela, as it is the perfect size for EDC use with a 3.5" blade, which is the sweet spot for EDC if you ask me.
"Gotta love living in 2019 baby, (63rc too soft on a production knife)"
--Shawn Houston
"I am still discussing issues of steels and performance at this stage."
--Cliff Stamp, May his memory be a blessing
"Cause geometry cuts, .....steel determines the level and the duration"
--Roman Landes
"Life is GOOD!"
--Stefan Wolf, May his memory be a blessing
--Ken Schwartz, May his memory be a blessing
"But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of 'designing in the dark' "
--Sal Glesser
--Shawn Houston
--Roman Landes
"Life is GOOD!"
--Sal Glesser
