questions about Delica edge
curious
Post by curious »
Having kept my Delica virgin for the last while I decided to do minor cutting on a springwater bottle the other day <img src="smile.gif" width=15 height=15 align=middle border=0>
After two cuts I noticed that the VG-10 blade was notched up in three places minorly. I have yet to purchase a Sharpmaker but my guess is that I should touch that up as opposed to leaving it correct? Or would a steel rod help?
Since the edge bevel is so thin that it get damaged so easily should I try to make it thicker? What is the factory angle, 15 degrees on each side or 20 on each?
Thanks
Edited by - curious on 6/4/2003 4:36:26 PM
Sword and Shield
Post by Sword and Shield »
Steel it lightly and don't worry about it. A few licks on a strop could also work those dings out easily, as it's simply where the edge folded over a little.
The <img src="spyder.gif" width=15 height=15 align=middle border=0> factory edge is between 30 and 38 degrees, and varies both by model and by the person who did the grinding. If you plan to use it hard, run it to 40. If not, 30 is sufficient.
By the time you read this, you'll have already read it.
Knife Knut
Post by Knife Knut »
You definitely want to take care of this. It can and will get worse if left uncorrected.
Knife Knut on a shoestring budget.
