Spyderco Waterway Impressions
Today I received my Spyderco Waterway!
The Waterway is the latest fixed blade from Spyderco.
It is constructed out of heavily textured G10, and LC200N rust proof steel. This is my first LC200N blade, and being a huge fan of H1, I'm very excited to test it out long term.
One of the first things I noticed about this knife, is that its almost the exact same size as my favorite folding Spyderco - the Police 4. It's about 9.5" overall, with a 4.5" blade.
The knife is very comfortable to use. The slight negative angle makes it feel more natural in the hand compared to straighter designs, and the angle the hand is placed in makes it feel like an extension of my body.
The handle is VERY textured. It is extremely secure in my grip, with or without gloves on. If anything about this knife could end up dividing people, I could see it being this.
The texture is amazingly grippy for what the knife was designed for, but the texture can be a little too abrasive for certain things. If you want to carve a lot of hard wood with the Waterway, your hands would probably appreciate gloves.
If, as some people here have mentioned, you want to carry the Waterway in a defensive capacity, you'll want an undershirt (Just like with gen 2 M&P Shields). The handle texture would be a bit much rubbing on bare skin for an extended period of time. Something with a smoother texture like the Ronin 2 is better suited for that application.
It's a very interesting texture, because it really locks your hand into place better than anything I've tried, but it can be overkill if you're not using it with your hands soaked in fish blood.
Two things jumped out at me in terms of ergonomics. The complete lack of a thumb ramp means I can extend my thumb as far forward as I want, without anything getting in the way like most Spydercos. This was one feature that initially attracted me to the design.
Something I did not know until I held the Waterway is that the scales are rounded rather than being flat slabs with a texture. This more rounded shape makes the knife more comfortable to use for extended periods.
The neutral, ergonomic handle shape terminates in a prominent guard. Between the extremely grippy texture and deep forward guard, the Waterway is extremely secure in the hand. Stabbing it full force into a log in reverse grip is no issue.
As I mentioned earlier, this is my first LC200N knife. So far I am happy with how it has performed, but keep in mind any impressions I share are based off a single evening of testing.
My Waterway arrived shaving sharp. I've read that wasn't the case with some of them. There were small bits of kydex on the blade the first few times I sheathed it then drew it out, but they stopped showing up after blowing out the sheath.
The knife showed no noticeable difference in sharpness after doing a little food prep, cutting paracord, paper and cardboard, and splitting some wood for a fire.
The blade shape is wonderful. There is enough belly that the Waterway does great slicing food on a cutting board. It is light and ground thinly enough that it could fill the role of your main food prep knife in camp. The tip is very pointy and pierces nicely. The spine is very flat, which makes it work well for scraping food off a cutting board into a pot.
There is a choil, but it's not quite a full sized choil. It is large enough that you can use it for more delicate work, but I would not suggest it for your main working grip. I wouldn't call it an after thought, but it's definitely intended as a back-up grip rather than the primary.
The spine came sharp enough to make tinder with a fatwood stick, scraping thin curls off with the upper corner of the blade. It also sparked my ferro rod nicely.
As I promised, I tried some batoning with my Waterway. I sectioned off a few 2-3" wide branches with my folding saw, then split them into quarters. The knife handled this just fine, despite whacking the pretty thin tip with a good amount of force.
Lastly I would like to touch on the sheath. I forgot to take photos of it, so you'll have to wait for my video.
There are two details I like about the sheath.
First, it is taco-style, where one end is folded over. This creates a lighter, more minimal footprint than Spydercos typical pancake style sheaths. This is especially nice if you carry scout style, or clipped to the front of your belt. This is where I like carrying smaller fixed blades I'll be using frequently, since its a little easier to draw than reaching under a jacket when the knife is vertical near my hip.
The other detail I appreciate is the lip for you to push off with your thumb when drawing the knife. Many taco style sheaths omit this feature, which means you need more of a pulling motion to draw the knife. Carried scout style, this can make the sheath slide around as you draw and re-sheath the knife. Being able to push off with your thumb eliminates this potential issue.
Overall I think this is a perfectly executed sheath. I would not change a single detail if I had made this with my own kydex. Hats off to Spyderco for nailing it.
I'm not much of a fisherman, but I'm sure the Waterway would fill its design purpose with aplomb. I will try to test the Waterway out on some fish sometime this Spring, but unlike the knifes designer, I'm a complete novice :o
https://youtu.be/gT_mmsW_jo8
If you have any questions I can answer, feel free to ask!
Re: Spyderco Waterway Impressions
This space is reserved for follow up posts.
Doeswhateveraspidercan
Awesome ViVi can’t wait!
Always my favorite reviews to read. I have no intentions of buying this knife, I just appreciate a solid review of a knife used in real world/outdoors situations. Can't wait for the video Vivi.
Wed Mar 20, 2019 8:34 pm
Thanks for the kind words.
If work is slow enough I can do some editing here. Just don't tell anyone :D
SF Native
Post by SF Native »
Vivi,
Nice review. I think you are really going to like that steel. It falls in nicely with what you have said you like.
And glad to know we have a definitive answer to the baton question. But I knew it could.
Bloke
Post by Bloke »
Great to read such a favourable first impression.
Eagerly awaiting mine to arrive. :)
Every time I use mine I think ultimate Filet knife. Lance nailed it all others will walk in his shadow.
wrdwrght
Post by wrdwrght »
Would anyone here be disappointed that the WaterWay’s cutting edge is most like the Military’s? Not me. What a total winner Lance’s design and Golden’s execution is.
I’m looking forward to the paces you’re going to put the WaterWay through, Vivi. Still planning to baton? Doh!
murphjd25
Post by murphjd25 »
Great write up. Thanks for the read, can’t wait to hear you report back after some use. I’m really digging some of the new fixed blades coming out, and hope to get a WaterWay someday.
Josh
SpyderSeth
Post by SpyderSeth »
wrdwrght
Post by wrdwrght »
SpyderSeth wrote:
Wed Mar 20, 2019 11:19 pm
Oops. Missed that.
Looks nice!! Do you happen to have any pics that show the spine / the tip / the distal taper towards the tip from above? So to see how delicate or not the tip really is? Though I guess this will be on your video anyway..
/ At first sight I did not like, that the handle has no "rear guard" or "hook" whatsoever at the rear hand so to keep the hand in place. I usually like to have this on my fixed blades, cause it makes (light) chopping easier. But then I realized how amazingly light the Waterway really is (which is a good thing!) and consequently not a chopper at all anyway.
dogrunner
Post by dogrunner »
Very helpful review. Looking forward to your continued experience, particularly with edge retention, sharpening etc. Edge holding was always the problem with H1 in PE. I love the overall blade profile and I think your comments just bumped the waterway to the top of my purchase list. Looks like the perfect size and shape for a good general purpose fixed blade.
Zatx
Post by Zatx »
What an excellent review! I can’t wait to get back to the states and pick mine up from the post office on Monday.
You spent considerable time writing about the handle texture, but it’s important to note that a quick pass with 220 or 400 grit sandpaper can tame that aggressiveness. It’s always best to start with too much texture because it’s easier to take away than put back. I actually hit coarse G10 with a 6 or 12k sandpaper which polishes/burnishes the finish. It basically takes the microscopic tops off of the texture, but leaves enough grip. It’s great for saving jeans pockets (with folders).
The Meat man
Post by The Meat man »
Excellent review Vivi as always. I'll be looking forward to hearing more from you about the Waterway.
- Connor
dogrunner
Post by dogrunner »
For winter carry the textured handle looks pretty good as is. The waterway is really growing on me.
So far I have only used it in the kitchen and I absolutely love the handle The texture is such that no mater how wet and soapy or covered in whatever I am confident it will never slip and I am secure knowing the finger guard will keep my fingers out of the blade in wet or greasy conditions.
elena86
Post by elena86 »
You forgot to mention something important... at least for me : thickness behind the edge !
Marius
( Rabindranath Tagore )
