Warehouse knife
Cao87
Warehouse knife
Post by Cao87 »
Hi I am new here and was wondering what spyderco knife would be good for
Working in a warehouse. I also wear gloves so I would need something that
Would have a decent size handle and a good steel and that is crazy expensive
Another question is a pouch that is easy to get a knife and pen and sharpie out
Because I use it all the time
Re: Warehouse knife
Tenacious or Endura
Colorodo
Re: Warehouse knife
Post by Colorodo »
Manix2 CPM 4V.
Re: Warehouse knife
Colorodo wrote:
Fri Feb 22, 2019 8:16 am
Manix2 CPM 4V.
That's a bit fancy for a knife that's going to get thrashed.
eRoc
Re: Warehouse knife
Post by eRoc »
Used to work in a warehouse in my mid 20's. If I could go back I would use my Squarehead. Doesn't have a decent handle like you want, but it works ok with gloved hands. Hang it off a lanyard on my wrist or a retractable keychain on my belt. I used to open boxes, set my knife down, grab product and walk off forgetting my knife. Retractable keychain + Squarehead is perfect combo for this. Small and cheap enough so you could carry 2 in case one gets gummed up from opening boxes.
Maybe not the best for cutting down boxes or those poly straps, but maybe something like a Squarehead/Tenacious combo would have you covered.
Cao87
Re: Warehouse knife
Post by Cao87 »
Sorry I meant not crazy expensive
Re: Warehouse knife
I wouldn't call cutting cardboard, tape, nylon pallet straps and stretch film getting "thrashed"
last time I worked in a warehouse I carried a Military in S60V.
If you want something really affordable check out the combo edge Byrd Cara Cara for $20-25
Colorodo
Re: Warehouse knife
Post by Colorodo »
I carried a Manix 2 CPM4V and didn’t trash it for warehouse work. I did change the scales though.
Re: Warehouse knife
I work in a warehouse and switch between a number of different knives that all do well for me.
Off the top of my head, the VG10 Wharncliffe Delica, Combo Edge Delica, Lil native, and Squarehead are probably my most used at work right now.
Re: Warehouse knife
Colorodo wrote:
Fri Feb 22, 2019 9:09 am
That's more so what I was getting at. I'd hate to drop that knife in those scales, on the concrete!
spyderg
Re: Warehouse knife
Post by spyderg »
I used to use my first Spyderco in a warehouse. Cruwear Manix 2. It was great although I was always a little worried about the tip. Somewhere in an old post I talked about wanting a Manix with more of a sheepsfoot to give it a stronger tip. I think one of the Caribbean models has a blade like what I was after. Also the D’allara. Actually if I still worked in that setting I’d prob grab a D’allara as it’s as close to what I was after as I think I’d ever get.
Marulaghost
Re: Warehouse knife
Post by Marulaghost »
I open a fair amount of boxes and i tend to find my Dfly works for most of it but if i get worried about breaking the tip or something I'll switch to my lil native.
If you need more blade or a bigger handle than me,
Maybe look into a delica (or endura!) Warncliff.
If you need something beefier than that, maybe a manix 2 LW (maybe look at the s110v version)
bearfacedkiller
Re: Warehouse knife
Post by bearfacedkiller »
I worked in a warehouse for many years and always thought my Yojimbo2 worked well. I didn't cut a lot of cardboard or open many boxes but I did cut lots of shrink wrap and all different types of banding.
Cao87
Re: Warehouse knife
Post by Cao87 »
Also was wondering if you know of any pouches that fits
A knife an pen and sharpie that also has outside carry
VashHash
Re: Warehouse knife
Post by VashHash »
I'd go with an SE native 5 light weight. Great for pallet strapping material, boxes, shrink wrap, etc, etc. I cut most of those things and a decent amount of manila rope too.
Sumdumguy
Re: Warehouse knife
Post by Sumdumguy »
Caribbean, if you can swing it.
Or
Native 5 Salt, if you can't.
-Thomas Jefferson
Re: Warehouse knife
Cao87 wrote:
Fri Feb 22, 2019 10:00 am
Try one of the Leatherman sheaths. The main slot will fit a good sized Spyderco, while the accessory slots will hold a pen and sharpie.
termite
Re: Warehouse knife
Post by termite »
Dragonfly H1SE?
Chinook3
Re: Warehouse knife
Post by Chinook3 »
Byrd Raven 2
My response is "Just because you can't see it, doesn't mean it isn't there, it just means you can't see it". Sal G.
Re: Warehouse knife
Hi Cao, eRoc,
Welcome to our forum.
