Domino & Dice Owners; please read
mad german
Has the issue with Spyderco and their washers & bearings been blown out of proportion by the “YouTube gurus”? I own a Dice and Domino and absolutely love them.
A coworker has owned both a Dice and Domino since they came out and carried them both daily, and uses them daily as work knives. He’s not had a single issue with either knife. Did he just happen to get a good pair of knives? Or has the “issue” been blown way out of proportion by guys like apostlep and others?
Any other Dice / Domino owners concerned or worried about future problems with your knives, or has it not even crossed your mind?
Thx for the input, everyone.
My collection is ever changing!
- curlyhairedboy
Re: Domino & Dice Owners; please read
Never had a problem with my Dice, or with my Domino when I had it.
I have a Dice and while it isn't the best flipper I've tried it isn't broken or impossible to flip or anything. Love the XHP as well!
/ David
Never had a problem with any of my Dominos. My blue G10 Domino in CTS-204 is a dream to open and close. Silky smooth indeed. I am about to purchase the one with red scales to complete my collection. Domino will be such a sought after folder in a few years from now... mark my words.
Marius
( Rabindranath Tagore )
I have two of the dominoes and they flip flawlessly for me and have for the past couple years .
Rich (Candyman)
Rich (Candyman)
Do not wait. The time will never be 'just right'. Start where you stand, and work whatever tools you may have at your command and better tools will be found as you go along. -Napoleon Hill
Never had a problem with my Domino. Flips admirably.
My domino is great. Flips fine every time. Dice, not so much. Some have said it’s the lower blade weight that doesn’t carry as much momentum. I tend to agree. I have noticed that zt’s, for instance, has a much stronger detent and need more pressure to fire so the flip really well.
I still think the thumb hole is the best way to open and faster than a flipper.
My dominos are great. No dice here
No issues with my Domino. I wouldn't worry.
- Johnnie1801
Have both, never taken them apart or even touched the screws, no issues here. I think it helps to keep them clean and lubricate once in a while.
Jon
Jon
Oh yeah, let me make something clear. My dice that doesn’t flip well was picked up second hand. It may have been taken apart by previous owner. My perfect domino was new from solid dealer.
mad german
To which question did you answer "yes"?murphjd25 wrote:Yes.
koenigsegg
I have two dominos and have had two dice. The red domino is not as good of a flipper as my black one. The black one flies open with the most gentle bump of the flipper. I tried loosening the pivot a fraction last night on the red one and that seemed to help a bit. The dominos/dic felt gritty and I felt needed to be cleaned and oiled. This didn't make them that smooth until after adjusting the pivot screw, now it's much better. I think at one point a few pivots might have been over tightened at the factory or by a user and this bent the washers but I don't think it's a problem if you don't torque them down.
DrawBackwards
I've had my domino for a couple of years, and it has always worked well for me.
Sorry I should have been more clear German! About the problem being blown out of proportion by a few “YouTubers”. I have not had any problem with my flippers, they have been more then great! It’s a shame because I think it’s scared off some people from trying flippers from Spyderco, and they make some good ones IMO.
Josh
JRinFL
I have both and neither are good flippers compared with my two ZTs. Not even close, however they are better than CrKTs I have tried. If you ignore the flipper and use the hole for opening, then there are no complaints. I can understand why some grind the flipper tab off.
Both of mine are early production models and have always flipped great. Domino almost sounds robotic it's so smooth.
Michael Janich
Thank you all very much for this discussion. The opinions and experiences of those who actually own and use our products are always the ultimate measure of whether the knives are serving their intended purpose or not. We also closely monitor all returns of knives for warranty consideration by specific model. Your positive experiences mirror ours.
Thanks again for sharing and for your continued confidence in our products.
Stay safe,
Mike
Stay safe,
Mike
mad german
Thanks again everyone, including you, Mr. Mike! The more I carry my Dice, the more I like it's smaller size.
