Sharpmaker - what else do you use?
Snorky
Post by Snorky »
I imagine many on this forum use a Sharpmaker.
But is that all? Do you use something else* as well as the Sharpmaker? If so, what and why?
Do you find you use the SM as a part of a wider sharpening routine, have you 'outgrown' the SM, or has the SM meant you stopped using other sharpening systems?
*For the sake of argument, I'm including the Diamond/CBN and the Ultra Fine stones for the SM in the 'something else' group.
Larry_Mott
Re: Sharpmaker - what else do you use?
Post by Larry_Mott »
I bought a KME system for setting a good symmetric edge but i maintain it with the S.M.
Snorky
Post by Snorky »
Larry_Mott wrote:I bought a KME system for setting a good symmetric edge but i maintain it with the S.M.
Good plan. Do you use just the standard SM stones, or have you pimped it out with the Ultras?
TriggerThumb
Post by TriggerThumb »
I don't know a ton about sharpening, but I just ordered some dmt mini hones to try out. You get 3 continuous diamond surfaces in course, fine, and extra fine for under $20. Seems like a steal to maintain a good working ege on the high hrc super steels if you can maintain the appropriate angle.
Our truest life is when we are in dreams awake.
-Henry David Thoreau
I do all my reprofiling and edge repair with DMT diamond bench stones. I couldn't imagine using the sharpmaker for that, it'd take forever!
PanChango
Post by PanChango »
While I have a set of Norton bench stones, I mostly use an Edge Pro for heavy lifting and touch ups with the sharp maker.
Tdog
Post by Tdog »
I use my Edge Pro for knives that need re-profiled or have significant chips. (Usually brought to me by family or friends) Once fixed I give them the friendly "talk" about taking care of their knives. I use my Sharpmaker for routine maintenance and "fine tuning". Probably never "outgrow" the SM. Sort of relaxing, spending time keeping the edge. :spyder:
Edge Pro for reprofiling, Dremel for stropping serrations.
xceptnl
Post by xceptnl »
In order of importance:
Spyderco Benchstones (M,F,UF)
Spyderco 701 profiles (M,F)
Spyderco double-sided pocketstone
DMT benchstones
DMT aligner
*Landon*
SF Native
Post by SF Native »
Sm with cbn rods mostly. Recently got an edge pro but have not had the time to mess around with it yet.
I used a Sharpmaker exclusively for a long time. I was basically just using it to touch up the knives I had using the 20° side. Not long ago I bought some Moldmaster stones that I clipped to the SM rods. Those greatly increased the functionality of the SM for me. I was even able to reprofile with them but it was still a lot of work. So a couple months ago I bought a Hapstone V7 to do the heavy work and polish bevels. I still use the SM for touch ups and adding a microbevel after reprofiling.
zhyla
Post by zhyla »
Unless it’s serrated or a recurve I do everything on sandpaper on a granite tile. I have wet/dry sandpaper from 100 grit to 5000 grit.
Canazes9
Post by Canazes9 »
I’ve got dozens of stones and hone steels and I am fairly proficient at sharpening by hand. Once I bought an Edge Pro, added diamond stones and 2300 & 4000 grit wet stones, it is mostly what I use now. Never owned a sharpmaker, but have used one - works well.
David
Post by The Deacon »
Almost all my carry folders and kitchen knives are PE and I sharpen them freehand with DMT diamond whetstones. I do own a Sharpmaker, but only ever use it to sharpen serrated blades, mostly a K05 Utility.
dj moonbat
Post by dj moonbat »
I like to set and refine a primary bevel a few degrees below 30, or a few degrees below 40, and do periodic touchup on the microbevel with the Sharpmaker. I like using an Edge Pro clone for that first step.
bh49
Post by bh49 »
Sharp Guy wrote:a couple months ago I bought a Hapstone V7
Why did you choose HApstone over EdgePro?
bh49
Post by bh49 »
WE sport&field for reprofiling
Sharpmaker for maintaining microbevel
Larry_Mott
Just the standard kit. Although I have a strop too with "Smurf poo" compound on the flesh side. :)
bh49 wrote:Why did you choose HApstone over EdgePro?
I like the upgrades the Hapstone offers over the EP. I really like that I can use a wide variety of stones.
Bloke
Post by Bloke »
I have a SharpMaker as well as Diamond and UF rods and I probably don't use it as often as I should. :rolleyes:
I have a few Lansky's I haven't used in a while as well and a Hapstone Pro I use to set bevels and I generally maintain edges with simple leather and sometimes balsa wood strops. :)
