New Black Karahawk- Fit & Finish?
Boar-gen
Post by Boar-gen »
Hi there,
I have just received the new black Karahawk and while the finish is great, the fit- not so much. Since I have the first generation Karahawk, it's very obvious to me that the black Karahawk I received is not of the same quality- as can be seen of the pictures below.
But the worse part is that it have a serious vertical blade movement, while the blade on my first generation Karahawk locks firmly in place.
My question to those of you that have the new Black Karahawk is if I just happen to get a knife which found it's way though the QC- despite having the worse fit I have ever seen in a Spyderco folder? Or is this, of some reason, what to expect?
Thanks and Regards,
Boar-gen
jstrange
Re: New Black Karahawk- Fit & Finish?
Post by jstrange »
Definitely a difference in the production quality between those.
:spyder: jstrange
Boar-gen
Post by Boar-gen »
Hi jstrange,
Yes, a very obvious difference in production quality between the new black Karahawk and the first generation Karahawk. Looking at close up picture on Internet of the new non-coated Karahawk, it seems to have the same great fit as the first generation.
In case I just got a bad knife, I just received a 2nd black Karahawk and unfortunately it has the same bad fit. If I hold it up against the light and look at the spine, I can even see the screws in between the liners and the locking mechanism. I am very sorry, but the TiCN coated Karahawk is not of the Spyderco standard I am use to!
I am returning both knives to the local dealer for a full refund. So sad!
Boar-gen
Liquid Cobra
Post by Liquid Cobra »
I was able to handle a few of these at my local shop and noticed they all had this problem as well.
@liquid_cobra
RLDubbya
Post by RLDubbya »
I just checked. My black-coated Karahawk from KnifeCenter does NOT have this problem, it looks quite close to the non-coated example in the pic.
Different production runs, maybe? Odd. I guess I would suggest that you don't give up on the K'Hawk based on my experience, which has been just stellar.
Michael Janich
Post by Michael Janich »
Dear Boar-Gen:
One of the necessary compromises that comes with black coatings is that adjoining parts can't be finished together. In the case of the satin-finished Karahawk, the G-10 ring spacer is installed and THEN the back of the handle and interior of the ring are sanded so everything is perfectly flush. This is impossible with the TiCN-coated liners because sanding would remove the coating.
We are constantly looking for ways to improve our products and will definitely take your comments into consideration to see if there's a practical way to tighten the tolerances on the ring fit of black Karahawks.
Thank you for your feedback!
Stay safe,
Mike
Boar-gen
Post by Boar-gen »
Hi Mike,
Thank you for the confirmation and explaination. But honestly, the fit on the two Karahawks I had were so bad that I had to return them. And having a black coating on the Karahawk could be done by doing the fitting first and the coating after that. Sure one extra step in the manufacturing process, which would result in a higher price. But personally I would gladly pay a higher price and have a perfect fit compare to the fit I got. And it was not only the finger ring that had problems with the fit. The whole locking mechanism looked like it was not properly screwed together.
Thanks and Regards,
Boar-gen
RLDubbya
Post by RLDubbya »
One thing I did notice: every single scale screw on my copy was incredibly loose, had no Loc-Tite applied - and once tightened, all the gaps closed. I never did have any blade play in any direction. However, if I loosen the scale screws to where they were as I received the knife, I pick up the gap and can see light through the entire length of the handle.
Bob
Josh623
Post by Josh623 »
Michael Janich wrote:Dear Boar-Gen:
Stay safe,
Mike
Mike, could it not be finished together prior to the coating, then disassembled and coated? This would seem to remedy the issue.
