What this means is I have been trying (or rather not trying through neglect) to create corrosion on the steel. I have various knives in this steel. Some from Spyderco and some customs. My normal routine is probably 10x more likely to make a knife rust than what the average land bound user puts an EDC through but to try to test the limits of this steel I have taken things much further. I have lc200n knives that NEVER see a drop of fresh water. I purposely leave them covered in salt and blood everyday. The fixed blades live inside kydex sheaths. Some on the deck of the kayak and some in compartments. They stay in there 24/7 (some laying in shallow pools of saltwater, without a rinse and bake in the tropical heat. (I have done the same testing for years with H1) The point of all this is to get to the truth about the level of corrosion resistance of these steels. I have been subjecting them to a level of abuse and neglect that leaves me confident that if I can't create corrosion in them then it's simply not going to happen.
What I have found after years of this type of "abuse" is that H1 is a fully rust proof steel. I have never been able to make the steel corrode in any way. Yes, after months of this level of exposure one can see some corrosive bleeding from the hardware or the residue corroding on the blade etching but nothing, and I mean NOTHING, I have done has been able to cause any corrosion or rust on H1.
So a year ago i started testing lc200n and I have put it through the same rigorous conditions and I have found it to also be 100% corrosion proof...until just now.
I have multiple fixed blades in this steel and one of them lives in a compartment in my kayak in its sheath, resting in saltwater residue. I have not used that particular knife for a few months and it did some fish work on the last outing. Yesterday when I pulled it from the sheath I noticed a small spot at the tip about the size of a pin head. I wiped it off thinking it was probably dried blood but it didn't wipe off as easily as I thought. When I scraped it off with my fingernail the feel of it let me know that it might actually be a spot of corrosion. I was surprised but interested.
When I got back home I brought the knife in and examined it with a 12x loupe. What I found was indeed a tiny spot at the tip where some corrosion had occurred. As I said the visible red spot was about the size of a pinhead but once that was wiped off (easily) then there was nothing visible to the naked eye. Under magnification however, I could see some VERY tiny pitting on the steel.
So I have been able to cause the most minor levels of corrosion in lc200n, but the more interesting question is how? I do not have the answer to that yet. I am reticent to believe that this is a result of exposure to saltwater. I say that because I have multiple lc200n knives that have lived under the exact same conditions and have been there much longer than this one. NONE of them have ever shown ANY corrosion and even in this example the corrosion was isolated to one tiny spot. That is not consistent with the idea of the steel corroding as a result of the overall saltwater exposure of the entire blade.
The two conclusion I can think or are that
A) something in the Heat treat left a tiny area of the blade susceptible to corrosion. I am not a HT expert but this explanation seems rather unlikely to me.
B) That part of the bade was left exposed to something far more corrosive than saltwater. This is the most likely scenario and the culprit is likely bile and acid from a fish's belly that was left on there for months.
At this point I am only guessing but what I can say now is that it is possible to create rust/corrosion on lc200n. I REALLY hope this post is taken in context. I hope this does not get read and repeated as "surfingringo says that lc200n is rust prone!" :rolleyes: In the interest in keeping this in context let me give a numerical ranking. If we were ranking steels on corrosion resistance and H1 were a 10 then the next closest steel I have tested is s110v and I would give it about a 7. With those numbers as context, I would call lc200n a 9.95. No normal human is going to make this steel rust. Trust me, It's as close to rustproof as a steel can come but when it comes to being fully corrosion proof I still have to give a slight edge to H1.
What does that mean about my thoughts on using the steel? Not much really. I still prefer lc200n to H1 for my plain edge knives by a wide margin. I get much better performance out of the edge and he steel is rust proof to the point that I am totally comfortable still leaving them on my kayak in their salty sheaths. The only change I might make is giving the knives a quick rinse in saltwater after i clean fish on the kayak. Honestly though, I'm not even sure I will do that. I am rather curious to see if I can get this to happen again and I am not convinced that I can. I will keep trying though.
