First of all, thanks to Sal for sending these out. Second, wow. These are far and above the nicest Byrds to date. Fit and finish meets or exceeds the Tenacious line in my opinion. Blade stock is thicker and made from Carpenter's bd-1 and it wears Sal's signature proudly. Grinds are clean and the jimping is precise and exactly where it should be. Lock up is solid and the lock release is easily accessed. The g-10 feels quality and the pocket clips are brushed SS. Hardware looks high quality as well. Liners are all skeletonized. These are quality pieces well worth the higher price over the original versions. I'm sure the US steel is part of the cost; I like 8Cr just fine so we'll see how bd-1 is as a replacement.
My initial thought opening the Raven was it felt like a small super leaf. The Crow puts a somewhat smaller blade in a well designed and ergonomic handle that gives a 4 finger grip with or without the choil. I like both of these knives a lot already. If fhe Ti Byrds are coming from this maker, they will be impressive for sure. They need to give this factory more work.
Some teaser pics:
-Nick
Last in: N5 Magnacut The "Spirit" of the design does not come through unless used. -Sal
Hi araneae, nice reveiw I too just purchased the Raven 2 getting use to it and liking it. Bought the knife to take the place of my Tenacious which I also really like no issues except ergo's really. I have been waiting to purchase a knife in this steel CTS-BD1, personally not a real hard knife user but just enough to get them dull and re-sharpen, the Raven 2 will be no exception. What about you what kind of "work" do you plan on putting your Raven 2 through? thanks :spyder:
My response is "Just because you can't see it, doesn't mean it isn't there, it just means you can't see it". Sal G.
I'm looking forward to you continuing comments. I like the Tenacious a lot for what it is in the price range, but, I could not get entirely comfortable with the ergonomics of the handle. I am interested in your experience with the Raven in that regard.
Today the Raven got a little use at work. I cut some dirty burlap off a balled tree and some jute twine. Also opened a box up. The factory edge lost its hair shaving ability. I won't sharpen it yet. The blade has picked up a few light scratches. Going to try and give it some more work this week.
-Nick
araneae, when these two knives are closed and you put a little pressure on the spine, is the blade solid or does it move?
My Crow, the stop pin presses on the blade and it doesn't give. On my Raven, it feels like the closed is resting on the detent and when I press on the spine it gives until the choil hits the stop pin.
-Brian A distinguished lurker.
Donut wrote:araneae, when these two knives are closed and you put a little pressure on the spine, is the blade solid or does it move?
Mine seem firm in the closed position.
-Nick
