What is the real Spyderco blade logo ? In the below pictures logo are slighlty different : see the "triangle". Is it possible that could exist differents logo ?
Spyderco knives are made under contract in a number of different facilities. It is more than possible for the logo to vary slightly, it is almost certain.
It's difficult to judge if a knife is genuine by the look of the :spyder: logo. Each maker has their own methods of stamping or engraving it and may use different methods on different models or on different blade steels within a single model, or on different runs of a given model and steel over time.
I agree 100%, they will of course vary by the facility and technique used.
Your bottom pic isn't a real blade BTW, no FRN handled SB folder just says "Super Blue" on the blade, they are labeled "Super Blue/420J1." That pic was one used for advertising the new sprint steel before they actually came out.
IG: the_irradiator
If you ask me, the one you've posted with the "SUPER BLUE" on it is a prototype or a rendering. You can see the laminate line and all the laminate blades came with different wording on them.
Each factory seems to have a different engraving. I'll have to pull out some of my Seki models to see if there are any differences.
-Brian A distinguished lurker.
As an example, these four :spyder:s are all on models produced by the same Japanese maker, two on different versions of the same model. Note the variety of sizes of the triangle inside the bug's pincers:
CLICK ON THE THUMBNAIL BELOW TO SEE THE FULL SIZE PHOTO
Great post The Deacon, and thank you guys for your advices.
I was trouble in my case, as the bug mouth is different from my firts delica 4 (flat ground black) and my last delica 4 NLEOMF.
I searched all over, but my Forum-Search-Fu is weak with this new setup. I recall a thread a while back that showed microscopic closeups of how each of the factories makes the spydie bug etch. Perhaps another can help me, but I know our resident engineer Clip posted this picture in his "Under the Microscope" thread. It is a GB so this the the Taichung logo example.
