Better lock-back for Delica/Endura models
elena86
Post by elena86 »
As much as I enjoy new lock-back models(Native5,Chaparral) my Delicas and Enduras have a special place in my heart.In fact, my old saber grind Delica was a trustfull companion over the years.I quote Sal saying about the new lock-back "...on the Native5 lock-back, we're using closer tolerances, refined shapes and a different mfg method". Don't you think Delica/Endura line also deserves an improved lock-back ?
APS
Post by APS »
Only if it doesn't increase the cost.
Adam
jabba359
Post by jabba359 »
Oddly enough, the improved backlock on my 2013 Forum Native 5 has a lot more vertical play than any of my other backlocks (Delica 3, Delica 4, Endura 4, FRN Stretch, FRN Native, etc.). I had never noticed any bladeplay before with the other knives (unless I'm specifically trying to detect it), but it's quite apparent with my Native 5. It's entirely possible I got a far less than optimal specimen of the new lock, however.
-Kyle
:bug-red
http://www.spydiewiki.com
Cujobob
Post by Cujobob »
You don't necessarily need to fix a problem that doesn't exist.
bornagainprimative
Post by bornagainprimative »
I am pretty happy with my delicas lock up having just recently got mine it actually impresses me how sturdy it is. Has it ever failed on you?
Own: C81GPBN2 x 2
Wanted: FB30GP, FB37GGRP, C180GP, C10FPBN x 2, C11FPBN & FB35PBK and a C204MF most of all!
morgaj1
Post by morgaj1 »
I am very happy with the lock on my Delica. If it ain't broke...
Blerv
Post by Blerv »
I don't know. I had a Native5 for a while and the lock seemed more clunky than my Japanese Spydies so I sold it. If that's "improved" (and customary) I'll stick with version 1.0.
StuntZombie
Post by StuntZombie »
I was under the impression that the new backlock was eventually going to be applied to the Delicas and Enduras. I may have imagined Sal saying that though.
Chris
GoodEyeSniper
Post by GoodEyeSniper »
What is upgraded about it?
Bill1170
Post by Bill1170 »
Like Cujobob says, no need to fix what isn't a problem.
We're always tweaking the Endura dn Delica locks. We've made minor refinements over the years and will continue to do so. Everytime we, or they (our maker) learns of a possible improvement, we make it.
mattman
Post by mattman »
GoodEyeSniper wrote:What is upgraded about it?
Native 5 parts are cut/machined using the wire EDM process, allowing tighter tolerances.
Laethageal
Post by Laethageal »
I don't know about which version I used on my zdp-189 endura which failed on me, but I can say that my SB strech feel so solid it push me thinking my ZDP had a failure only due to random reason which we don't even know and that normaly doesn't happen.
I might give ZDP backlock another chance since the strech raised my opinion on backlock. I did love the ZDP so much, the issue I had with it's backlock was the only thing keeping me from buying another.
If it's not polished, call it a saw, not an edge!
The Mastiff
Post by The Mastiff »
I love the older style lockback on my Enduras, Stretch, and others. They seem to get smoother and smoother over the years and polish up very well. I'm in no hurry to see them go even though I also do like the new Native lock.
The Mastiff
What besides a broken tip on the blade was wrong with your ZDP Endura? You know there is several different versions of ZDP stretch that have been made over the years. If you don't want to try another Endura there are some nice Stretches available including an old discontinued Carbon Fiber ZDP stretch that is fairly easy to get.
Laethageal
The broken tip was a handling mistake made by a newbie and has nothing to do with the knife built quality or anything.
I already talked with sal about the trouble on the endura backlock the warranty team handled it to try to figure out. The lock wouldn't keep the knife open under light pressure. From what they told me, a part of the lock worn down. At first I was affraid it might have been difference in steel hardness between the part. I couldn't tell exactly what went on with it to cause the failure and I didn't want to try another ZDP to see for myself if the 2nd would fail or keep going strong. Maybe someday I'll buy another to see, but for now I seem to enjoy the SB stretch model I ordered as a replacement more then I would have thought! :)
I had a few short email with sal afterward and I am now pretty sure it was only random badluck of knife failing after 1.5 year and that I could thrust a new ZDP backlock. But knife budget isn't as some other have here. As much as I'd love to have more then 2 user (ladybug as an always on my keychain and strech at job) I can't afford to buy any knife unless I absolutly need it, which in my case mean my knife would be unusable. As much as I loved my ZDP endura in general, I don't have a clue what I'll get once my stretch need to be replaced. So many choice I might try something new to see how I love it. It won't be soon anyway and have much time to make up my mind :)
Post by Doc Dan »
I had suggested a new lock about a month or two ago but the idea was poorly received on this Forum. But, I agree...with the advent of the Powerlock there could be an upgrade of significance. Of course, this means redesign and retooling (expensive).
Blerv
Post by Blerv »
The lock on the current knife is stronger (IMO) than it needs to be given the thin blade and intent of design. It's part if Janich's MBC curriculum so essentially "combat capable".
Some people would like to fix things that aren't broken. I (like some) believe that those funds could be allocated elsewhere. From more consistent F&F to maintaining the low msrp. That and often there is a trade-off for strength besides cost: Diminished ease of function.
mattman
Post by mattman »
Blerv wrote:The lock on the current knife is stronger (IMO) than it needs to be given the thin blade and intent of design. It's part if Janich's MBC curriculum so essentially "combat capable".
Well said, Sir.
GuusdeJong
Re:
Post by GuusdeJong »
sal wrote:We're always tweaking the Endura dn Delica locks. We've made minor refinements over the years and will continue to do so. Everytime we, or they (our maker) learns of a possible improvement, we make it.
my stainless delica had a little side to side and very noticable vertical blade play in it. I love the knife and I EDC it but it's a shame it came with movement after I spend €80 on it. I can fix the side sto side in a vice but the vertical play annoys me a great deal.
Not that I hate the knife but it is fustrating when you get a new knife and it isn't as solid as you thought it would be.
Does it void my warranty if I try to fix it yourself?
I just hope the harpy is more solidly build because that one is next and is €122 where I want to get it.
Spyderco's I own in order of purchase: Bug, Ladybug 3 PE, Delica 4 stainless handle SE
Spyderco's on wishlist: Harpy C08, lil' matriarch C162SBK, Rescue C45OR, Cricket C29P, Police C07S, Endura C10S stainless handle, Military C36GPBK, Civilian C12G
'Mistakes are always forgivable, If one has the courae to admit them.'
-Bruce Lee
