Is this the S110V lightweight Manix 2?
Shakyamuni
http://www.howesknifeshop.com/spyderco/ ... ming-4/16/
I remember the discussion about the S110v lightweight Manix 2 being dark blue and FRN instead of FRCP, so this might be it!
Manbug G-10, Salt I PE, Pacific Salt SE, Caly 3.5, Green Forum Native 5, Green ParaMilitary 2, Centofante 3
- senorsquare
- senorsquare
No biggie if it's out of stock because it should be showing up at other dealers soon-ish. If this is a thing you want then you should be able to get one.Fancier wrote:The listed part number doesn't seem to match any other current models.
By the time you find out what it is it will probably be out of stock.
- bearfacedkiller
- PayneTrain
Preordered. Thanks!
Looks like I got one of the last ones about an hour ago...
I'm sure there will be plenty opportunities to snag one, but this is on my list. Might as well be an early adapter! Hope KW doesn't sell it for ten bucks less :o
A life is like a garden. Perfect moments can be had, but not preserved, except in memory.
-Leonard Nimoy
-Leonard Nimoy
- PayneTrain
twinboysdad
Ha, if it isn't what we're thinking it is, you will indeed be an early adapter!FCM415 wrote:Preordered. Thanks!
I checked this forum early enough to see this thread before they sold out of however many they had to presell. Quickly placed my order, minutes later, it showed out of stock.PayneTrain wrote:How? I didn't see that as an option.
-Leonard Nimoy
-Leonard Nimoy
