Prediction and hope
Prediction and hope
It is my prediction (and hope) that when those of you who obtain, and actually use, the new sprint run knives in Super Blue Steel, that you will finally understand why I love carbon steel (particularly 50100B/0170-6B) blades so much.
- SpyderEdgeForever
- Strong-Dog
Maybe its just me, but the only stainless steels that can compare to relatively simple carbon steels such as O1 or Superblue are really high end, VG10 just doesnt get me excited. Now CPM-M4, does everything so well (besides corrosion resistance) that I'd be happy with every knife I own to be made with it.
"For a second, I thought I was dead, but when I heard all the noise I knew they were cops. Only cops talk that way. If they had been wiseguys, I wouldn't have heard a thing. I would've been dead."
-Henry Hill
-Henry Hill
I've not had any issue keeping VG-10, 14C28N, AEB-L or CTS XHP ridiculously sharp. I guess I don't really see the advantages to carbon steels over stainless these days. I haven't seen the prices of VG-10, but I'd bet it's the most expensive of those I've listed....the others are available at affordable prices.
I've only done limited sharpening of Super Blue but it's quite different than VG10. My skills are lacking but I can get SB freaky sharp after drinking a few too many whiskeys :p .SpyderEdgeForever wrote:I am sure you have a great point on this, but, with all due respect, sir, isn't the joy of steels such as VG-10 Stainless that you get the best of the carbon and the best of the stainless?
Also, do you have or use any H-1 Steel blades and if yes, what do you think of them?
- bearfacedkiller
I carry a Super Blue delica a lot. Almost every day. I use it as a parer and mostly cut up apples and such. WONDERFUL!!! I reprofiled it by hand to get it less than 30 degrees (25ish). Now I just touch it up on the sharpmaker at 30 degrees. It isn't perfectly even (a little steeper on one side than the other) but man does it get sharp and on soft matter like produce it stays that way for a while. It doesn't lose its shaving sharpness in between touch ups.
I have learned that you can read about how great a steel is all day long but in the end the steel that takes the edge you want easily and holds it adequately is the best.
I'm sure this is not the greatest steel for everyone but for me (in my limited experience) Super Blue is extremely easy to keep at the level of sharpness I desire.
I will be buying both a dragonfly and a stretch.
I never realized thatBlerv wrote:I've only done limited sharpening of Super Blue but it's quite different than VG10. My skills are lacking but I can get SB freaky sharp after drinking a few too many whiskeys :p .
would enhance my sharpening skills, Blake. I appreciate the tip, brother! I'll take it under advisement.drinking a few too many whiskeys :p .
But, kidding aside, I also seem to get sharper edges on my carbon steels, in general (and Super Blue in particular). This is unscientific observation on my part and may just as easily reflect something in my sharpening skills/technique as opposed to a quality of the steel. I'll freely admit that, though I can't attribute the difference to my skills being whiskey enhanced. All my knives are sharpened solely under the influence of coffee
Ken
玉鋼
Actually, if I understand it correctly the carbon steels should sharpen more quickly, which most of us will equate with sharpening more easily. This is because the chromium content required in to make the steel stainless also makes the steal very wear resistant. So, because of the significant increase in wear resistance, it's going to take more passes on the same sharpener to abrade as much stainless steel as carbon steel.
While modern stainless steels are worlds beyond those early attempts (by quality manufacturers) and way, way, WAY beyond the initial spate of "junk" stainless found then (and even now) the properties of two given steels, stainless or not can be radically different (or, admittedly, quite similar) in any given pairing.SpyderEdgeForever wrote:isn't the joy of steels such as VG-10 Stainless that you get the best of the carbon and the best of the stainless?
VG10 is a terrific all round "stainless" blade steel. It holds a good edge reasonably well for a respectable duty cycle and is relatively corrosion resistant. Not as wear resistant as S110V. Not as corrosion resistant as H1. But a good steel that will serve most EDC applications very well.
When comparing it to a steel like Super Blue. I find Super Blue takes a finer edge. Holds it longer. And corrodes much more readily.
So, no, to me, VG10 is not 'everything Super Blue is and it's stainless' It's a trade off of properties you value over ones you value less. Only you can decide how you value these properties (or whether you can even perceive them). If you don't find you can get Super Blue sharper than VG10 and/or that it holds that edge longer, you would have no reason to ever choose Super Blue over VG10. If you work in an area where corrosion is a major concern, you may well prefer VG10 (or better, H1)
Ken
玉鋼
I too like Superblue, even if acidic apples corrode the very apex rather fast, unless immediately rinsed. Regarding carbon steels in general, I like patina and that it is a self-healing surface. I just re-profiled my Caly 3 SB sprint to an acuter angle by freehanding on DMT diamonds. The DMT aligner kit I held in my hand (as it does not allow acute edge angles if you clamp it to the blade, and that would be slower anyway than freehanding) has almost all the plastic backed dotted diamonds bent, and the red one so much so it bit to the blade face. While annoying, most of the scratches will likely be hidden once I've eaten a few apples more.
While we are hoping, I hope we will eventually get more thinly ground high edge stability steels in stainless format. I'd think AEB-L type of steels well heat treated would offer most what makes Superblue so nice, with the exception of being way more corrosion resistant. The new Frontier by Ed Schempp would be a splendid candidate as it's got a thin blade to begin with. Also the Chaparrals would work well with such a steel.
- xceptnl
Well said Ken. I don't have the vocabulary to offer anything more informative than what you have said. I love my VG-10 and my Superblue. Each have their strengths. As Blerv stated I can get my free-hand edges on Superblue easier, even whie enjoying a cocktail . As of late I have been using jackknifeh's technique of using the higher (finer) grit stones to sharpen my Superblue (and others) because I am forced to use more repetitions (giving me practice) wit less wasted removal of steel.kbuzbee wrote:VG10 is a terrific all round "stainless" blade steel. It holds a good edge reasonably well for a respectable duty cycle and is relatively corrosion resistant. Not as wear resistant as S110V. Not as corrosion resistant as H1. But a good steel that will serve most EDC applications very well.
Ken
Yeah, kinda, sorta, not completely.... Yes, chromium is the main component contributing to "stainless" and, yes, if your only difference between two steels is chromium content, what you say is generically correct (factoring out hardness and processing differences) But remember, these days we have more than just these 2 classifications of steel. We have low->high allow stainless. And low-> high alloy non stainless and a wide spectrum of possibilities in between these four data points. Additionally, what those alloys are (W, Ni, Mo etc) and how they are treated matters. So you can have a non stainless steel with incredible wear resistance and a very stainless steel that wears relatively easily, if that makes sense?ugaarguy wrote:Actually, if I understand it correctly the carbon steels should sharpen more quickly, which most of us will equate with sharpening more easily. This is because the chromium content required in to make the steel stainless also makes the steal very wear resistant. So, because of the significant increase in wear resistance, it's going to take more passes on the same sharpener to abrade as much stainless steel as carbon steel.
Ken
玉鋼
Thanks Landon,
Ken
That can be a very "Zen" experiencexceptnl wrote: As of late I have been using jackknifeh's technique of using the higher (finer) grit stones to sharpen my Superblue (and others) because I am forced to use more repetitions (giving me practice) wit less wasted removal of steel.
Ken
玉鋼
- Pinetreebbs
My Super Blue Endura has cut many yards of cardboard since it landed in my pocket. Just a touch up on the fine stones followed by a strop is all it takes to keep it sharp. We buy just about everything except groceries on the Internet and shop at Costco so I get plenty of cardboard to cut up for the recycle bags our city uses. In addition to the usual stuff, we recently purchased a tread mill that was shipped in a huge cardboard box, it was a pleasure using the Endura to cut it all up so easily.
I agree. I'd love to see a new focus on knife blades (or, is it a return to an old focus ) of sharpness. Designing, treating and manufacturing blades for sharpness.Mallus wrote: While we are hoping, I hope we will eventually get more thinly ground high edge stability steels in stainless format. I'd think AEB-L type of steels well heat treated would offer most what makes Superblue so nice, with the exception of being way more corrosion resistant. The new Frontier by Ed Schempp would be a splendid candidate as it's got a thin blade to begin with. Also the Chaparrals would work well with such a steel.
We've seen a lot of focus on wear resistance in the last couple decades, culminating in steels like S110V etc. Knives that, given a sufficiently thick edge, can hold it under normal use, virtually forever.
And we've seen a lot of focus on corrosion resistance, culminating in "steels" like H1 which will never rust.
There has been some focus on toughness for chopping/impact intensive applications.
But I really think 90% of EDC use benefits most from a blade that is very, VERY sharp. This means very thin behind the edge. Steels and geometries that support this would get my attention over any of these other categories. I'd love to see more zero edge designs. The comment was made in another thread to out Opinel Opinel. I love that idea, be it carbon, stainless or whatever.
Ken
玉鋼
It's a very nice steel and the world is a better place for its existence. It doesn't get a particular VanHagar song stuck in my head, though, like AEB-L hardened to RC63 (queue cheesy hard rock anthem now!).SpyderEdgeForever wrote:I am sure you have a great point on this, but, with all due respect, sir, isn't the joy of steels such as VG-10 Stainless that you get the best of the carbon and the best of the stainless?
I've got a Spyderhawk in H1, and Atlantic Salt SE in H1, and a Tasman Salt SE in H1 (bought three like I promised to do and sold off two so others could enjoy the majesty of a serrated hawkbill in an exotic alloy). It's soft, has the wear-resistance of a moth, and I like it tons. Most soft steels are a total pain to sharpen (underhardened AUS-6, AUS-8, and 420HC come to mind), but not H1. Also, H1 is a very idiot-resistant steel (my Atlantic Salt SE; especially now with a titanium Low-Rider clip courtesy of STR) is all that is man (you can see the thick 1970's mustache and IROC-Z if you hold it in the light just right).SpyderEdgeForever wrote:Also, do you have or use any H-1 Steel blades and if yes, what do you think of them?
You aren't a physician in my HMO's health plan are you?Blerv wrote:Cocktails are the key :D . Menial tasks are exciting when you are inebriated :p jk
"I knew you before you knew you had hands!" ~Tracey Brogan
"Ah-ha! A Spyderco moment!" ~Michael Cook
"Hawkbills - Sink in the tip and let it rip!" ~Axlis
"I would rather have questions that can't be answered than answers which can't be questioned" ~Richard Feynman
