Thinking about shortening the handle just a tiny bit. The blade doesn't fill the handle (never really did) but I'm hesitant because the grip is pretty amazing as it is.RadioactiveSpyder wrote:Nice work David, you keep moving that RL to ever higher levels of coolness. What evil plan do you have in mind for the next possible mod?
Would you start creeping into the liners to do that to the G10 on the butt end? If so, probably wouldn't be worth it to do so. What I've been dreaming about is an Anso style textured G10 handle (like the Perrin PPT and Zulu) for one of these, after all it is an Anso-designed knife! Either that or go with nice wood scales, matching the size/specs of your modded handle. :)Evil D wrote:Thinking about shortening the handle just a tiny bit. The blade doesn't fill the handle (never really did) but I'm hesitant because the grip is pretty amazing as it is.
