Greetings fellow Forumites,
Thinking about picking up a Manbug in ZDP-189. I have no experience with the steel. With all Spydies I assume the edge retention is without question. How difficult is this steel to resharpen?
ZDP-189 Question
- Spidernoir
ZDP-189 Question
~Jeff
- _centurio_
I recently purchased and gave away a pair of ZDP-189 knives, a dragonfly and a ladybug - I would suggest touching the edges up on the fine sharpmaker rods before you start using them, and then touch them up regularly to keep it sharp. With my EDC knives, I do so once a week or so and never have to worry about them getting really dull.
Regards,
Bruno
"Each of the builders wore his sword at his side as he worked." - Nehemiah 4:18
Bruno
I had a ZDP-189 Chinese Lum and a couple green Delica 4s (hollow ground). I couldn't get them super sharp and decided to part with them but that was long ago. After learning about the Edge Pro Apex sharpening system recently, I'm giving it another shot with a Delica 4 hollow ground that I have incoming. The Sharpmaker couldn't get it shaving sharp but with the Edge Pro, it should be a cake walk.
DeathBySnooSnoo
