Tenacious anomalies?
_centurio_
Post by _centurio_ »
Hey all,
my name is Oliver (20y.o) and I'm from Austria. I love knives, especially folding knives. I am a user but also a little bit collector :) . I am very good at grinding/sharpening and I love to do it everytime...
I do own a lot of Spydercos, my new user should be the Tenacious all black version, so I bought it.
I noticed some "anomalies" when disassembling the knife (tagged on the picture).
Are these things normal and do they affect stability when using the knife?
Thank you very much,
greetings from Austria! :) :)
Clip
Post by Clip »
The slot in the liner allows for easier actuation of the lock. Not sure what that extra hole in the blade is for, could be the detent position that holds the blade closed.
Shouldn't cause any problems as that's how the knife is designed.
Chris
Post by The Deacon »
Am sure Clip is correct regarding the lockbar cut, and that both holes are intentional. I suspect the hole in the blade is there to aid in either finishing of the blade or assembly of the knife at the factory and fits over a pin in a jig/fixture.
sharpguitarist
Post by sharpguitarist »
Hey guys,
I have the black bladed, and the satin bladed tenacious', and I've never had the black one apart.
My satin blade does not have the extra hole, and the lock bar is solid.
I never noticed the skeletonized lock bar until i saw this post.
Maybe the newer versions have been revised.
My satin Tenacious is one of the early releases.
Just wanted to point out the differences.
Later,
Don
endgame
Post by endgame »
The dlc is the newer model with upgrades wich they are
God'sMyJudge
Post by God'sMyJudge »
Your title would be a cool name for a band.
endgame
Post by endgame »
Centurion for a band name? It might be one.
ginsuwarrior
Post by ginsuwarrior »
I think he meant "Tenacious Anomalies."
The Tenacious Anomalies are a really interesting group, I believe they are a transvestite barber shop quartet, that actually shave members of the audience while they sing, quite talented.
endgame wrote:Centurion for a band name? It might be one.
endgame
Post by endgame »
Ha.
Pockets
Post by Pockets »
Welcome centurion! My guess is that every hole is there for a reason :D even if it's not obvious why.
Delica PE, Dragonfly Salt SE, Stretch SE, Manbug SE, Mule 16, Sage 1, black/satin PM2, Native 5
_centurio_
Thank you very much guys!
I hope that the additional hole in the blade will not affect the stability of the knife.
Sorry for the theme title, English is not my first language...
Greetings from Austria,
Oliver
anagarika
Post by anagarika »
I think it's ok, as the normal use will bear the forces vertical. If horizontal force is applied (prying), I think the tip will snap first.
JAYJAY
Post by JAYJAY »
I have a DLC tenacious I got a while back and when I took mine apart it did not have either of the holes from your picture
w3tnz
Post by w3tnz »
Bad robot? Monday morning blues? CQI?
I don't think the extra hole in the tang will cause any issues, sorry can't offer any real help but welcome to the forums :)
RanCoWeAla
Post by RanCoWeAla »
That cot out on the lock bar will cause it to break quicker just like a skeletonized pocket clip. I have a Tenacious and the next size under it that I happen to notice the other day that have the pocket clip mounted for tip down carry that puts the jimping on the thumb ramp right against your hand as you go in and out of your pocket. Anyway when I tried to change it for tip down carry the screws won't come out. It appears that the screw heads were stripped on both knives at the factory. These two knives have got to go just as soon as I get somewhere to sell or trade them. I can't imagine why anyone eould mount a clip that eay.
Blerv
Post by Blerv »
In nearly all cases improper assembly or disassembly leads to tool problems over manufacturing decisions.
The Adventura was full of holes in the handle and blade yet I don't recall any issues with durability.
_centurio_
thank you very much!
edge holding is great, i like the knife very much as a user!
greetings,
oliver
