Delica Trainer blade replacement question
noddy
Post by noddy »
I tried searching on this but didn't find anything, so, if someone could help I'd be really very grateful
Question is: does the red-handled Delica trainer accept standard Delica blades?
A red-handled FRN Delica has haunted my dreams of EDC for some time now. And it is about time to do something about it I think :)
Thanks. Any tips, assistance or suggestions warmly received
Holland
Post by Holland »
I'm not positive it takes normal blades, I imagine it would, but it's better to keep the same lockbar with the same blade. So the best thing to do is swap the frn scales and leave everything else original
Spyder-fan
Post by Spyder-fan »
I've thought about doing this myself. Let me know how it works out.
BAL
Post by BAL »
The other way to think about this is to ask if the red scales will fit on a regular Delica
and I believe that they will. I think that others have done it in the past. You can also
rit-dye scales to darker colors, although I haven't personally done it.
noddy
Post by noddy »
Thanks all .. that is hopeful and I will probably go ahead and get the bits and pieces together.
Scale swap, I see :)
notos&w
Post by notos&w »
Yes. But switch the lockbar too. I have a crimson (red scales darkened with rit dye) Delica with a zdp-189 blade. RTR.
Gunslinger
Post by Gunslinger »
I have done this with an Endura 4
Yes, it will work. Make sure you keep the lock back lever with the blade because they are fitted together.
[SIGPIC][/SIGPIC]
noddy
Post by noddy »
Thanks for the prompts on the Rit BAL, notos&w, and thanks for that great pic of the serrated Endura Gunslinger :)
