rust resistance
rust resistance
Is the rust resistance on the byrd knives equal to aus-8 steel spyderco used to use on their older knives?
- spyderedge
- The Deacon
Both have similar compositions and similar percentages of chromium and molybdenum. For that reason, I'm inclined to think they'd offer similar rust resistance, assuming similar finish.
I have a lot of 8Cr knives, one is Resilience, live in Indonesia. No issue with rust on blade so far. Since I also use them for food, the blade gets cleaned thoroughly (no oil) an it's working fine.
If you're concerned, a wipe with wd40 and spray into hidden parts will prevent most rust
I have more concern with rust forming between liner and outer slab (FRN, G10). Usually I take it apart, apply wd40 and reassemble.
My original Byrd knife was a coated Raven. It would show rust around salt water even with the black blade...I've used 2 different Byrd Rescue knives both on freshwater rivers in the midwest and as a commercial fisherman on the North Atlantic. I would say that they have slightly less rust resistance than AUS-8A comparing them to an old FRN clip Delica. The one I currently use (about 2 years lobstering with it) has no real pitting on the blade...I even take it diving to clear rope out of boat propellers. I have no idea how bad the innards are because I've never taken it apart...The first one has experienced near total immersion in seawater since the day I lost it overboard :D how bad it's rusted is anybody's guess... :D :D :D
BLUETYPEII
Re:
NO! Don’t use WD-40 , WD-40 actually attracts dust, a simple gun oil would be more effective and offer better lubricationanagarika wrote: ↑Sun Dec 23, 2012 8:52 pmI have a lot of 8Cr knives, one is Resilience, live in Indonesia. No issue with rust on blade so far. Since I also use them for food, the blade gets cleaned thoroughly (no oil) an it's working fine.
1 Byrd and 30 “others”
