ZDP Hard to Sharpen
jnichols2
ZDP Hard to Sharpen
Post by jnichols2 »
I decided to sharpen my ZDP-189 Caly 3.5 today. It took me over an hour.
I had to go to the diamond rods to redo the left edge angle. After that, it took three trips through Medium, Fine, and Ultra Fine to get it really sharp.
Now that I'm finished, the edge is much smoother than any of my other knives, which all have "toothy" edges.
I'm satisfied with the result, but my ZDP Ladybug was MUCH easier to sharpen. :rolleyes:
Ladybug, Delica x 2, Endura x 2, Military Black, Manix 2 XL, Civilian, Harpy, Caly 3.5 CF ZDP-189, Sage 1
Ankerson
Post by Ankerson »
ZDP is a high alloy steel with 20% Chromium and 3% carbon designed to be run at high hardness in the 64-68 HRC range so it would be somewhat harder to sharpen than the other steel.
It's the carbides and the high hardness of ZDP that causes that, but the payoff in edge retention makes it worth it.
jnichols2
Post by jnichols2 »
Ankerson wrote:ZDP is a high alloy steel with 20% Chromium and 3% carbon designed to be run at high hardness in the 64-68 HRC range so it would be somewhat harder to sharpen than the other steel.
Actually, I'm not sure the edge retention on my two has been all that much better than my CPM S30V knives. But, the Caly 3.5 is definitely one fine knife.
Holland
Post by Holland »
Yep sharpening ZDP can be a PITA, best to touch up ur blades frequently
Cliff Stamp
Post by Cliff Stamp »
jnichols2 wrote: After that, it took three trips through Medium, Fine, and Ultra Fine to get it really sharp.
If you didn't move past the medium until it was smoothly shaving, push cutting newsprint, etc. it would be much faster.
jnichols2
Post by jnichols2 »
Cliff Stamp wrote:If you didn't move past the medium until it was smoothly shaving, push cutting newsprint, etc. it would be much faster.
I didn't realize it would shave or push cut on Medium. :confused:
Cliff Stamp
The edge can shave off an even more coarse finish, but the medium is relatively high grit wise and can easily push cut newsprint. The fine and uf remove very little metal so the edge should be very sharp before you go to them to minimize time on the rods.
jnichols2
Post by jnichols2 »
Cliff Stamp wrote:The edge can shave off an even more coarse finish, but the medium is relatively high grit wise and can easily push cut newsprint. The fine and uf remove very little metal so the edge should be very sharp before you go to them to minimize time on the rods.
Thanks Cliff.
It really helps with ZDP if you use a loupe when sharpening, and pair that with a sharpie marker to make absolutely sure you're hitting the edge. If you're hitting the shoulder, you'll be making 1000s of strokes before you wear it down and hit the edge and start making it sharp again. ZDP is not a steel for lazy sharpeners...you've gotta maintain that edge or you'll end up hating the knife. The longer you go between touch ups, the longer you can expect to spend sharpening it.
440V is my worst
Post by JD Spydo »
I've told people this several times but yet few people believe me>> I truly find the older 440V ( S60V) of Crucible's to be harder to sharpen than ZDP-189. And I find XHP to even be just a bit more difficult to work with than ZDP.
I like what Cliff Stamp said about using the medium stone on the 204 Sharpmaker until you get an edge that you can shave arm hair off with. I've been doing just that here in the past 4 months and it does seem to work pretty well.
When I do sharpen either one of my ZDP blades I mainly use 2 of my diamond benchstones to reprofile with unless I'm using the 204 Sharpmaker then I use the 204 diamond stone to do a lot of the hard work and the medium to set it up for a final finish.
But to me ZDP is not one of my worst steels to sharpen. I even find some of the other tool steels to even be a bit more stubborn at times.
chuck_roxas45
Post by chuck_roxas45 »
ZDP IS hard to grind but once you've put on a proper bevel, it's easy to touch up with the sharpmaker. Removing so little steel(with a microbevel) doesn't really need a lot of grinding.
jackknifeh
Post by jackknifeh »
I agree with Chuck about the micro-bevel on ZDP. Cutting is easier with low edge angles. But ZDP is so hard it's VERY difficult to get the edge sharp and maintain it with a wide bevel. Also, the hardness of ZDP means micro-chipping can be an issue at lower angles (below 30° inclusive). This is my experience anyway.
So, using a micro-bevel gives the edge more strength to reduce micro-chipping and makes touchups very easy. Touching up ZDP frequently on the micro-bevel (or edge bevel) will keep the knife sharp and keep you from needing to work on the back bevel as often.
ZDP is the hardest steel I had to learn to sharpen. I'm no pro. I'm only semi-experienced. But, once I knew what I wanted or needed to do it's a nice steel to use.
phillipsted
Post by phillipsted »
Personally, I find ZDP no harder or easier to sharpen than other steels. It takes the same techniques - it just takes L O N G E R to get a good edge.
Set a spell. Take your shoes off. Your patience will be rewarded!
TedP
Brisket
Post by Brisket »
My personal revelation in sharpening came while working with ZDP and it was exactly what Cliff Stamp was referring to. I had acquired a dull ZDP Delica and to make an extremely long story short came to realize after great frustration and trial & error that I was overly concerned about removing excessive material with coarser abrasive and had developed a tendency to progress to a finer abrasive before it was time. ZDP helped me discover my sharpening flaws that were not obvious with sharpening softer steels and as a result my sharpening results on all steels improved.
Recent :spyder: Additions: Stretch CF ZDP, Caly 3 Super Blue, Gayle Bradley, PM2 M390, PM2 CTS-XHP, Cat CF, Caly 3.5 Super Blue, MT17, Native 5 S110V
In the Crosshairs: Stretch Super Blue, Manix 2 S90V
jnichols2
Post by jnichols2 »
Evil D wrote:It really helps with ZDP if you use a loupe when sharpening, and pair that with a sharpie marker to make absolutely sure you're hitting the edge. If you're hitting the shoulder, you'll be making 1000s of strokes before you wear it down and hit the edge and start making it sharp again. ZDP is not a steel for lazy sharpeners...you've gotta maintain that edge or you'll end up hating the knife. The longer you go between touch ups, the longer you can expect to spend sharpening it.
Evil,
I did use the sharpie, that was what told me to use the diamond rods to fix the left edge.
To others that recommended a 40 degree micro bevel. That seems like a good idea.
Cliff Stamp
As a general rule, if you are attempting to sharpen a knife and you are having to remove a lot of metal then there is a problem as knives, even when blunt, require very little metal to be sharpened. A sharp edge will be between 0.1 and 1 micron thick, even if it is blunted way down to 10% you are still only removing on the order of 10 microns of steel, 5 from each side to get it back to full sharpness. This should happen immediately unless you have an extremely wide apex bevel. If this is the case then lower the apex bevel angle, even 1-2 degrees below the desired final angle. Sharpening will then again become instant, and as necessary work the relief grind as needed, on the more coarse abrasives to keep the final sharpening bevel very small in width.
phillipsted
Cliff Stamp wrote:As a general rule, if you are attempting to sharpen a knife and you are having to remove a lot of metal then there is a problem as knives, even when blunt, require very little metal to be sharpened. A sharp edge will be between 0.1 and 1 micron thick, even if it is blunted way down to 10% you are still only removing on the order of 10 microns of steel, 5 from each side to get it back to full sharpness. This should happen immediately unless you have an extremely wide apex bevel. If this is the case then lower the apex bevel angle, even 1-2 degrees below the desired final angle. Sharpening will then again become instant, and as necessary work the relief grind as needed, on the more coarse abrasives to keep the final sharpening bevel very small in width.
You are absolutely right, Cliff. There is a huge difference between re-profiling and sharpening.
TedP
