Techno Stiff Opening
Hi all. I've been having a bit of an issue with my new techno. The knife is very stiff at the initial opening, getting the blade out of the ball detent. After the detent disengages it is very smooth and travels well, but getting the blade to initially release is really stiff and requires quite a bit of force. I sat and opened it about 20 times and my forearm was sore. The pivot adjustment is fine, the blade will do a gravity drop when unlocked and travels well once I've overcome the initial stiff release. Is this something that will get better over time or is there something I can do to speed the process along and loosen it up a bit so that I can flick it open with my thumb without straining my wrist? I don't have much experience working on lockbacks aside from adjusting the pivot tightness, and I've never done any sort of adjustment to a detent before.
- The Deacon
With Customs officials in more and more countries declaring any knife that can be flicked open to be an illegal "flick knife", I think the more robust ball detents on some of the newer models may well be intentional.
The detent on my example is very strong as well, more so than any other Spyderco I've owned to date.
Personally, it's a non-issue since I generally don't flick my knives open...plus I find the sound and feel of the lock up to be much more gratifying when opened traditionally :)
-Jodi
It's not just in my head, it's in my heart.
KardinalSyn
I don't have a techno yet so this is just a thought. Perhaps it will smooth out after some time of constant use. Also try a wee bit of oil.
KardinalSyn
Do you think you can pry with that blade? Aimed at Techno owners here.
I don't have one but.....perhaps oil on the ball and work it a while.
Not uncommon with framelocks(have several), Strider is like that.
*I weakned the lock lug by bending(carefully) it back the other way, therby having less force on the tang, yet more than enough force to hold lock in place. In my case, I couldn't open it with one hand.
Or you can deal with it as is.
* You may not want to void the warranty, by taking it apart.
SCARAMOUCHE!
Thanks for the advice. I'm not looking to flick it with the snap of the wrist or anything, but as it is now I have great difficulty opening it with one hand. I was just hoping it would loosen up to be more like my meerkat, which is the stiffest spyderco I own. I realize it'll never snap open like my para 2 or sage due to the weight of the blade, but this thing is killing my wrist just to pop it open with my thumb. I oiled the ball and it still needs a ton of thumb strength to open with one hand. I know part of the problem is the shortness of the handle doesn't give me the full amount of leverage, but I still feel like with all the videos that I've seen on youtube for the techno that most people aren't having as hard a time as I am opening it with one hand.
Gah I just figured it out. Being my first framelock, I was completely unaware that I was pressing my middle finger against the framelock when opening, thereby adding pressure to the process and making it difficult to open. Much smoother now. Now I just gotta find a place to put that finger when I open it.
I was about to post this. It's very easy to apply enough pressure to the outside of the lockbar that it's forced inward and doesn't allow the detent ball to move out of the detent. Glad you figured it out!Phat B wrote:Gah I just figured it out. Being my first framelock, I was completely unaware that I was pressing my middle finger against the framelock when opening, thereby adding pressure to the process and making it difficult to open. Much smoother now. Now I just gotta find a place to put that finger when I open it.
Mine is stiff to open and much more difficult to close one-handed.
It got a little better when I loosened the pivot screw. But there's only so much the pivot can be loosened before it causes other issues.
Mine is also stiff to open and I'm glad for that. Techno is touted as a Mini Tank so I would hope it would be stiff. I am able to fingernail flick it open and wow is it loud hehe. I won't be doing that again. Normal one hand opening and closing using either hand is fine with me :)
My :spyder:s
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
The techno is absolutely flying now. I've been resting my middle finger on the edge of the framelock, barely resting against the hole, rather than pressing down on the lock. Been working it while watching the olympics and it's really loosened up nicely. I give it a little downward push then work it up and it snaps like a beast. Probably the most satisfying click of any of my knives. Just a solid thwack noise when the lock engages.
bayvillageidiot
It's supposed to be like that. Sebenzas right out of the box feel the same way.
I see from your last post that you've got the situation sussed.
My techno is three days old now, and the action is perfect.
In a very short time, the detente nib eases down enough to make for a smoother release, while still making sure the thing doesn't open accidentally.
The last thing you want is for it to open up in your pocket and cut off something you might need one day. :eek:
