Spyderco Endura Stiff. Any tips?
I have an endura 4 FRN for about a month now. I open and close it on average 10 or 20 times a day. I washed it with soap, blow dried it, put WD-40 then gun oil. Still feels tight. Any tips on what should I do?
- chuck_roxas45
Have you tried loosening the pivot a bit?
- araneae
Keep using it, it should break in. Better to start a little snug and wear in with some use IMO. Otherwise, very slight adjustment of the pivot should yield a smoother action without play.
-Nick
Last in: N5 Magnacut
-Nick
- chuck_roxas45
There's usually a sweet spot where there's no play but smooth action. Just adjust bit by bit.Kousii wrote:Yeah but then I get a little side to side play![]()
- chuck_roxas45
lmao!bal wrote:rumor has it that chuck has a nack for finding the sweet spot.
Years ago an old timer told me to make a slurry of Comet/Ajax and get it worked into the pivot area of a stiff Buck knife that I had. I recall it seemed to work. I like Michael Janich's version and would recommend that procedure. Also, sit in front of the TV and open and close a hundred or so times with the slurry.
You can't display a toad in a fine restaurant like this! Why, the good folks here would go right off the feed!
