A solid, durable, sharp and badass knife!?!?!
So i was doing a demo on a house the other day and i chose a cheaper knife as my sidekick (CRKT M16-10) to do some fairly dirty work i.e cutting some carpet, minor drywall..stuff like that. After words i was looking over my knife and it was fairly dull and had some blade play. So i was wondering wat a good "construction knife" would be..something that would be able to withstand some abuse, hold an edge and that i wouldnt worry about babying. Preferably a Spyderco bcuz they kick serious *** lol but ne brand would do i guess.
Also wat steel should i be looking at that would serve me the best in that aspect?? again something that is durable, tough and would really hold an edge.
I've abused my PPT with some of those types of usage but it would be better with a tool steel. Get a Gayle Bradley young man, or better yet a Cruwear Mule.
- razorsharp
- darkstar29
- IrishSpyder22
I think as a pure utility knife that would be perfect for carpet, drywall, etc... would be the Jason Breeden Rescue. I've got one and have never used or carried it. I got it because it was so different looking. I have to admit it's not one of my favorites. But, if I was using it for that kind of work, I think it would be ideal. VG-10 is the steel used in this knife. I'm not a steel-guru, but if I recall it's a durable steel.
http://spyderco.com/catalog/details.php?product=615
How much are you looking to spend? That will make a huge difference in suggestions......monster08 wrote:So i was doing a demo on a house the other day and i chose a cheaper knife as my sidekick (CRKT M16-10) to do some fairly dirty work i.e cutting some carpet, minor drywall..stuff like that. After words i was looking over my knife and it was fairly dull and had some blade play. So i was wondering wat a good "construction knife" would be..something that would be able to withstand some abuse, hold an edge and that i wouldnt worry about babying. Preferably a Spyderco bcuz they kick serious *** lol but ne brand would do i guess.
-Ryan
-Techno, cruwear Mule, Dragonfly 2 FRN, Assist, Endura FRN ATS-55 SE, Endura SS aus-6 PE, Persistence(Wife's)
-Wicked Edge
-Wicked Edge
no limit. when i look into getting something like this i refuse to carry nething but the best. The way i figure it, i'd rather spend a little more and get something thats really gona last and do its job well than be cheap and have to replace it in a month or 2rg02 wrote:How much are you looking to spend? That will make a huge difference in suggestions......
So would I.DiKa wrote:I would recommend Manix 2.
- darkstar29
- chuck_roxas45
For drywall and carpet? :eek:darkstar29 wrote:A Chokwe wouldn't be a bad choice, either..
- darkstar29
I think it would perform well. Why wouldn't it? Too thin and pointy?chuck_roxas45 wrote:For drywall and carpet? :eek:
I'm just putting ideas out there.. The Chokwe is a good/tough blade.
Don't have much experience with drywall, but for carpet slicing, it would be great..
Are there other blades more suited to both tasks? Besides the GB and Native that have been recommended?
I don't think a hawk blade would be as versatile either of those..
Maybe there's a fixed blade option?
I walk away slow tonight,
and cut through the air
with a curse, like a knife.
- chuck_roxas45
Manix in M4? Yab uses an S90V or an M4 Millie. Also, you won't get far using S30V for carpet and drywall.darkstar29 wrote:I think it would perform well. Why wouldn't it? Too thin and pointy?
If your knife is just for cutting the Military would probably be great. If you do any prying then I would look at the Manix series (the tip on the Military is really thin).
There won't be a huge difference in toughness between M4 and S30V, there is some but they're both high alloy steel types, once you move to the more basic steel types (e.g. 1095) toughness goes way up.
Look here for mechanical properties of steel from Crucible Industries.http://www.crucibleservice.com/products.aspx
Cannot Die Happy Without The Maxamet Yojumbo
- darkstar29
I don't know this Yab you speak of..sorry :o Does an M4 Manix exist with a regular lock type?.. I wouldn't recommend a blade with a lock I don't like.chuck_roxas45 wrote:Manix in M4? Yab uses an S90V or an M4 Millie.
I don't intend to argue with you, chuck. I was just offering suggestions to the OP.
It's all going to boil down to whatever he likes to use.. Any number of steel/knife combos are available..
edit: you edited while I was typing. Basically jacked my whole point about the Manix...which you changed to Millie..
