Want a liner lock ( maybe )
I'm really looking for a new knife, want to spend less than $50. I think I want a liner lock, but really do not like the look of the tenacious (and the others). Does :spyder: make another liner lock under $50? If not, could you recommend another knife?
There is much to be learned from one who never speaks
not that I know of. Other than the value line, the delica and enduras are the cheapest, but all back locks. You'd prbably have to spend twice that, but then your options really open up. Ofcourse I suggest the Gayle Bradley, or Perhaps a Sage 1Bradley wrote:I'm really looking for a new knife, want to spend less than $50. I think I want a liner lock, but really do not like the look of the tenacious (and the others). Does :spyder: make another liner lock under $50? If not, could you recommend another knife?
No.
I bought a Volpe for $50 once because it was discontinued and unpopular and a Sage 1 for $64 during a special promotion. I can't even think of a liner lock that might get discontinued that you could get for under $50.
- The Deacon
You can get a brand new Spin for under $50.
- I_like_sharp_things
I agree with Evil D.
I found a used Sage 1 for $65 on fleabay, so you might be able to find one close to your $50 goal. The little bit of extra money will be worth it every time you use the knife and enjoy it. :)
Jeff
Jeff
