What tool?
808spyder
What tool?
Post by 808spyder »
I was wondering what tool do I use to adjust clips on frn handles? Also where can I get that tool?
Fifteen54
Post by Fifteen54 »
A torx driver is what you are looking for. You can get an inexpensive one from Husky. I suggest getting a set that is t-5 through t-9 at least so you can disassemble a knife should it get very dirty...
http://www.homedepot.com/webapp/wcs/sto ... reNum=1846
You can tell a lot about a person by how they keep their knives.
808spyder
Post by 808spyder »
Thanks for the reply Fifteen54. The torx driver will work fine for blade adjustments. The tool I need looks like a shallow cross on the clip of frn handles (eg. Atlantic Salt).
razorsharp
Post by razorsharp »
808spyder wrote:Thanks for the reply Fifteen54. The torx driver will work fine for blade adjustments. The tool I need looks like a shallow cross on the clip of frn handles (eg. Atlantic Salt).
A flathead screwdriver will fix that problem :)
808spyder
Post by 808spyder »
Ok, thanks razorsharp. Sounds good to me.
Post by The Deacon »
Two coins. If you're in the USA, nickels work well.
Azwaiian
Post by Azwaiian »
808spyder,
Aloha and welcome to the Forums. Is the 808 a reference to the State or to the drum/bass beat?
808spyder
Post by 808spyder »
Thanks to The Deacon, two nickels looks like it would fit perfectly. spyderkoholic its the 808 state.
phillipsted
Post by phillipsted »
I always use pennies - but then again, I'm a cheap date.
TedP
808spyder
Post by 808spyder »
Haha, thanks phillipsted. Looks like I will be in no shortage of tools to adjust clips on frn handles. Thanks for all the replies and tips gang.
Azwaiian
Post by Azwaiian »
808spyder,
Mahalo for getting back and Aloha bra! It's good to see some Aloha spirit on the Forums. I'm originally from Oahu, Aiea side, now I live in Arizona! Desert heat out here, but we have plenty of the 808 Tribe!
Aloha again bra!
808spyder
Post by 808spyder »
spyderkoholic wrote:808spyder,
Aloha again bra!
Rajah dat Boss.
19cohiba75
Post by 19cohiba75 »
Was at Harbor Freight Tools today and picked up one of these for 7 bucks. Worked perfect for my clip change and pivot screw loosening on my Spyderco PM2. Has every bit you will need.
http://www.harborfreight.com/33-piece-p ... 93916.html
BAL
Post by BAL »
Welcome 808spyder. Great to have you on board. Aloha.
Onionman
Post by Onionman »
The coins and/or screwdrivers mentioned above should work fine. If you are afraid of getting scratches on the clip screw (which can be obvious if its black) I would suggest putting a paper towel or napkin between the screw and the coin or screwdriver.
The important thing was that I had an onion tied to my belt, which was the style at the time. You couldn't get white onions, because of the war. The only thing you could get was those big yellow ones...
cosmo7809
Post by cosmo7809 »
Onionman wrote:The coins and/or screwdrivers mentioned above should work fine. If you are afraid of getting scratches on the clip screw (which can be obvious if its black) I would suggest putting a paper towel or napkin between the screw and the coin or screwdriver.
I have also used some tape to not mar the surface of clip and barrel bolt.
Side note: I love Spydercos barrel bolt type clips. Just something about them that I prefer. Though I do love my wire clips.
Come Join Us Click Here
NYRich
Post by NYRich »
My favorite Torx tool is the Maxxdriver. It comes with T4,5,6,7,8,9,10 and 15 reversible bits which fit inside the handle. Very compact and has never failed me or stripped a screw.
About $7 if I recall.
808spyder
Post by 808spyder »
BAL wrote:Welcome 808spyder. Great to have you on board. Aloha.
Mahalos BAL
