How much of a difference do you notice with the flatgrind compared to the sabregrind ladybus when cutting?
Does it make a big difference with the blade that small?
zdp ladybug owners
- I_like_sharp_things
I haven't noticed any difference from the blade profile when cutting, but I have noticed that I have never seemed to be able to dull the zdp ladybug at all. About the only difference I ever noticed was when the vg-10 one was dull, it didn't open mail as easily/cleanly. Every time the zdp ladybug opens envelopes/packages like a fresh razor blade. I still sharpen the zpd ladybug when I sharpen the rest of my other knives. The ZDP just goes from sharp to extremely sharp while the others go from slightly dull to sharp. (I have never mastered getting a scary sharp edge on S30V...that might explain why I like vg-10 and H1 so much.)
I highly reccomend the ZDP ladybug, Great little knife. I only wish it was as rust resistant as H1 so I could use it on my work keyring. (I work in a warehouse and few knife blades stand up to my sweat.)
Grizz
Grizz
- jackknifeh
If you haven't tried Tuf-Glide and cloth on anything you have problems with in your pocket you may want to try it. I used Tuf-Glide on an M4 blade (non-stainless steel) then tried to put a patina on it. That means I TRIED to make it rust. No luck. I believe the Tuf-Glide protects against corrosion well enough that it is hard to cause corrosion intentionally. Also, I haven't had one spot of corrosion on anything I use it on since I started using it.gdwtvb wrote:I haven't noticed any difference from the blade profile when cutting, but I have noticed that I have never seemed to be able to dull the zdp ladybug at all. About the only difference I ever noticed was when the vg-10 one was dull, it didn't open mail as easily/cleanly. Every time the zdp ladybug opens envelopes/packages like a fresh razor blade. I still sharpen the zpd ladybug when I sharpen the rest of my other knives. The ZDP just goes from sharp to extremely sharp while the others go from slightly dull to sharp. (I have never mastered getting a scary sharp edge on S30V...that might explain why I like vg-10 and H1 so much.)
Grizz
Just a thought. BTW, I got the H1 Ladybug for corrosion resistance but I think I would have been just as safe using Tuf-Glide on any other steel I might have chosen.
Jack
That matches with my observations, comparing my ZDP Ladybug and my VG-10 D4, for casual whittling in the backyard. The only drawback I'm finding is the smaller size of the Ladybug, for any continuous use, I can't manipulate it as easily in hand as my Delica4.rodloos wrote:To me it seems to "bite" into wood more easily when I am making shavings, but I don't know how much of that is psychological because of my expectations.
Matt in Texas
Recovering BoyScout(TM), now doing GoodTurns(TM) fortnightly!
A cutting test on cardboard with my ZDP Ladybug sent me straight to Cutlery Shoppe to order a ZDP Endura.
C05, C05S, C10SRD, C10SBK(x2), C10FPBR, C10GRE, C10FPGR, C11, C11FPBK, C12SBK2, C14 C17 C21, C28BK, C28BK2, C28YL2, C36, C45, C54GPBN, C77, C80GPOR, C81, C81GS, C81GBK2, C85GP2, C86, C86P, C86PET, C90, C94, C95, C106, C109, C116, C122, C123CF, C123, C123GBL, C126(x2), C132GP, C135GP, C136, C137, C138, C140, C142, C146CFP, C148, C158TIP, C161GP, C162, C163PBK, C164GPBN, LBK, LBKII(x2), LYL3HB, LGRE3, MBK, FB20, FB23, FB24SBK, FB31SBK, FBPBK, MT12, MT13, MT16, Woodcraft.
