Mule work: What machines do you use?
I don't have a machine shop and I assume most of you don't either.
What machines do you use to make your handles? Dremels or something else?
For those who have reshaped the blade blank, what do you use to remove metal from that hardened blade blank?
Just trying to get some ideas. Can't find a machine shop willing to rent time for using it's grinders.
Thanks.
Revelations 20: The dead were judged according to what they had done as recorded in the books...Anyone whose name was not found written in the book of life was thrown into the lake of fire.
Thanks.
All you need is a drill press with a spindle sander attachment to do most of the shaping, metal, wood whatever. A bandsaw helps to bookmatch wood and cut a rough outline prior to shaping. A belt sander can help you attain flat sides and equal handle thickness, as well as exterior radius's.
Between those three machines you can pretty much make anything, knives included. If you can only buy one, go with a drill press. Delta has a great table top model for around $200. Spindle attachments range from $10-35 a set, then you should be pretty much good to go! Hope this helps!
- phillipsted
Actually, I use mostly hand tools to make mine - by choice. Nothing like the satisfaction of using your own two hands.
If this is your route, you'll need a couple of good files (10" flat and half round), a coping saw, a couple of pin punches and some appropriate-sized pin stock, and a vise of some sort. Not to mention sand paper, polishing compound, etc. You can purchase all this for the price of a decent tabletop drill press.
Don't get me wrong, I love my drill press. Its just that some times I prefer to take things into my own hands! :cool:
TedP
TedP
Worry less - Breathe more...
Spydie Fanatic #185
Spydie Fanatic #185
Cheers,cncyana wrote:What machines do you use to make your handles? Dremels or something else?
Stationary beltgrinder, Dremel, drillpress, files, saw, sandpaper.For those who have reshaped the blade blank, what do you use to remove metal from that hardened blade blank?
Just trying to get some ideas. Can't find a machine shop willing to rent time for using it's grinders.'
Get your own :rolleyes: It is my most used machine for metal, wood and leather!
Tomas
Tom
http://spyderco.com/forums/showthread.p ... t=tutorial
....and there is a part 2 as well. Use the search-function...
Tom
I used a bench grinder to remove the guard and the part of the handle that hooks down behind the little finger, making the end of the handle into an oval shape. It might be a touch shorter, but the feel is very different.cncyana wrote:gaj999, were you the one who reworked the handle and made it shorter?
