Help, Don't know what happened.
coonan
Post by coonan »
Took my old millie apart to clean & lube. Had it 15 years and never took it apart. Now I get 1/16 th of an inch of play up and down no matter how tight the screw is. What happened ? and how do I fix it. thanks for all help.
coonan
Post by coonan »
I also notice the blade sits farther down into the frame when closed, if that helps.
jossta
Post by jossta »
I assume you mean side to side, but side to side or up and down?
jezabel
Post by jezabel »
I'm wondering if you somehow got your stop pin mixed up with the others (assuming it's an older model), but start again and read this first http://www.spyderco.com/forums/showthre ... itary+lego.
J
FB04PBB, C07FS4K390, C12GS, C12SBK2, C36GS, C36GTIP, C36CFM390P, C36CFTIP, C36GPBORE, C36GPS2, C41BKPS, C44GP&SGY, C46PS, C46GPBK, C52BKP, C52FPGYE, C63G3, C65TIP, C70S, C81FG, C81GS2, C81CFM4P2, C83BM, C83GP2, C101GP, C101GPS, C101CF90VP2, C105, C134CF, C151GODTiPBK
jossta
Post by jossta »
^^Awesome.
Padawan
Post by Padawan »
I couldn't find anything in the forum rules that prohibits links to content on another forum, and in this case it should prove helpful, so here you go:
http://www.bladeforums.com/forums/showt ... c-Pivot?s=
jezabel
Post by jezabel »
jossta wrote:^^Awesome.
Thank Mr Blonde!
jezabel
Post by jezabel »
Padawan wrote:I couldn't find anything in the forum rules that prohibits links to content on another forum, and in this case it should prove helpful, so here you go:
Nice find, the eccentric pivot has been known to throw a few people off if their not expecting it. Personally I love them.
JNewell
Post by JNewell »
Excellent post and likely the solution for the OP. Note the date, though! - I don't remember when Spyderco stopped using the eccentric stop pin, but it was quite a few years ago.
coonan
Post by coonan »
As soon as I saw the words eccentric ,all made sense right now. 5 min. later Bingo . Thanks much. With magnification I could see it . Eyes are not what they were.
jossta
Post by jossta »
Glad you got it figured.
