Impressive bamboo cutting
- Michael Cook
:spyder: That's tamashigiri, dowels wrapped in tatami, serious stuff! I used to train Katori Shinto ryu. Japanese swordmanship looks so direct and simple until you train it and you realize that there is one correct way of doing everything and all else is wrong! There are no left-handed swordsmen in Japan! :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
- SolidState
The cut you're showing is a form of what is called mizu gaeshi. It's not too terrible to learn. Usually about 2-3 years of practice are needed, unless you want to do it off of the draw.
My brother is competitive in the sport under Mugai Ryu. I cut as well. The targets are the approximate resistance of a neck or a leg at the thigh.
If you think this is cool, check out Isao Machii or Big Tony Alvarez. James Williams is okay as well.
My favorite top-shelf Iaidoka is Tony.
http://www.youtube.com/watch?v=Ckow34_XgO8
This guy effectively uses easier mats to cut and make it look good. He still has a lot of skill.
http://www.youtube.com/watch?v=RS2YcBbubs8
"Nothing is so fatal to the progress of the human mind as to suppose that our views of science are ultimate; that there are no mysteries in nature; that our triumphs are complete, and that there are no new worlds to conquer."
Sir Humphry Davy
Sir Humphry Davy
- chuck_roxas45
- Dr. Snubnose
The embedded player doesn't seem to be working out so well:
http://www.youtube.com/watch?v=DoYpJqFNj40
:spyder: Come chat with us on IRC at #SharpThings! :spyder:
:spyder: Check out the SharpThings.net website too! :spyder:
- SkullBouncer
- defenestrate
Very cool (I couldn't see the embedded video either but I saw the links that were posted) - I am hoping to learn some japanese sword techniques myself and will be getting an inexpensive (thinking a few hundred $ US) combat-quality blade to learn with. Will probably be asking here for suggestions though I have a few ideas.
I've watched that James Williams video several times in the past and always enjoyed it. His form looks excellent to me, but I'm very much a layman cutter.
I have some monosteel beaters that I use for practice, also a few differentially hardened blades that I simply cherish, even though they are not true nihonto. I've been surprised how many good quality blades there are on the market these days, even if the fittings need to be repaired/replaced.
