Ffg Delica wear
I_like_sharp_things
Ffg Delica wear
Post by I_like_sharp_things »
I am a new member here and am a huge fan of Spyderco. I got my first Spyderco knife (blue ffg delica) a month or 2 ago. Within the first couple of openings some scratches began to show on the blade near the pivot. I assumed this was normal wear until I received my Tenacious and it hasn't happened at all yet. Are the rings on the blade of the Delica normal and if they aren't what can I do to fix it? Thanks in advance.
knife nut404
Post by knife nut404 »
You just need to untighten the pivot screw alittle
Spydies: edc forum manix 2
stag arms manix 2, endura 4,delica 4, ffg e4, para 2
Typical. Every Delica i've had got the scratches as have most of the other lock backs i've owned.
chuck_roxas45
Post by chuck_roxas45 »
I assume it still cuts well?
I_like_sharp_things
Chuck_roxas45: It definitely cuts great and is definitely my favorite knife. I just thought it was odd that this knife did this and the "cheaper" model didn't.
Knife nut404: I will try that when I pick up some torx bits tomorrow.
Spyder Count: 7
Jazz
Post by Jazz »
Don't let it bother you. :)
- best wishes, Jazz.
I_like_sharp_things wrote:Chuck_roxas45: It definitely cuts great and is definitely my favorite knife. I just thought it was odd that this knife did this and the "cheaper" model didn't.
It isn't about cost, it's about construction. My carbon fiber ZDP-189 Caly 3 cost quite a bit more than a Delica and the very first time it opened it made scratches on the blade. That's just how it is. It has to do with the liner construction and in my case the 420J2 steel on the outside of the blade being very easy to scratch.
araneae
Post by araneae »
I wouldn't worry about it. If you use it, it will get some character marks.
-Nick
Last in: N5 Magnacut
I_like_sharp_things
Thanks for all the replies guys. This knife is too nice not to use even with some scratches :D
Spyder Count: 7
chuck_roxas45
The circular scratches near the pivot area on my blue stretch makes the knife cut way better. ;)
razorsharp
Post by razorsharp »
I took my ambitious apart... "VOID" ...and it has some scratches , didn't affect the performance at all
Dench
Post by Dench »
You will notice every little mark on it for awhile, maybe even feel bad about it. Just because it's your "baby".
majornub
Post by majornub »
Dench wrote:You will notice every little mark on it for awhile, maybe even feel bad about it. Just because it's your "baby".
Don't worry, though, you'll get over once you start using it and then you will love it even more.
