Sage 3 Confusion
DevilDog1833
Sage 3 Confusion
Post by DevilDog1833 »
The catalog says blade length on the Sage 3 is 2-13/16", while the website says its 3". Which one is tellin' the truth?
Military (G10, PE), Endura II (SS, PE), 93mm Rescue (FRN, SE), Delica (G10, PE), Delica (FRN, CE), Delica Wave (FRN, SE), Delica Wave Trainer (FRN), UKPK Rescue (G10, PE), UKPK Drop Point (G10, PE), Dragonfly (SS, PE), Ladybug (SS, PE), Medowlark (G10, CE), Crow (Aluminum, CE)
Sequimite
Post by Sequimite »
The first is the cutting edge. The total blade length is 3".
Post by The Deacon »
Website is correct and there's an error in the paper/PDF catalog. All three blades are with a hair of being the same length. Sage 3 has a bit more edge length than the other two, because less of the choil is on the blade and more on the handle.
DevilDog1833
Thanks, Deacon. I guess I'll have to keep waiting for that Chaparral you got me all excited about.
