Worth it?
DeathBySnooSnoo
Worth it?
Original Manix, lightly used $200.
Good deal or bad?
Good deal or bad?
DeathBySnooSnoo
- THE PUNISHER
- Nifty_Nives
DeathBySnooSnoo
DeathBySnooSnoo wrote:Black, in box, minor wear on the clip, otherwise like new.
Recently I saw on few occasions NIB C95 PE sold around $240-270. I can be wrong, but if the only deviation from mint is minor wear on the clip, I think $200 is about right. And if will be able to get it for $140-150, than that will be your lucky day.DeathBySnooSnoo wrote:So if I could bargain down to about $140-150, that would be an ok deal you think?
Good luck. C95 is the great knife and IMHO is the best Manix ever made.
Perry
DeathBySnooSnoo
Possibly. I have been using my Manix 2 since I got it, but I like the longer and still heavy blade of the original, so there is a good possibility that I might very well use it at least as an option for daily carry..Spyderbro wrote:Box & all tells me it's taken care of? Are you gonna use it?
I have seen them in a range, a few go as high as about $250, but as low as $150. Those are all LNIB or NIB....so I was thinking that the $200 was a good start but I thought that maybe closer to $150 was a better place to be.bh49 wrote:Recently I saw on few occasions NIB C95 PE sold around $240-270. I can be wrong, but if the only deviation from mint is minor wear on the clip, I think $200 is about right. And if will be able to get it for $140-150, than that will be your lucky day.
DeathBySnooSnoo
SteelDragon
Not that it matters for a user but just fyi, there were two models in black. Basically a first and second version. You can tell by the jimping and the spydie bug. I would put a user in excellent shape at around $140-$160, and NIB around $180-$190, the Green Sprint around $200-$220. Just my humble opinion, good luck.
- The Deacon
Depends on how bad you want it. Someone who already has an original C95 and considers it to be something they want extras of will pay top dollar and be happy they got it. Someone who is just curious after hearing others rave about it may not. I'd call 200 a bit high, if it's PE, and quite a bit high if it's combo, but I'm not one of "true believers".
- Spider bite
