how can i clean g 10?
dzarren
Post by dzarren »
I recently acquired a new manix 2 in orange g 10 and around the cage ball lock on the g 10 theres already a bunch of crap accumulating from my hands rubbing agianst it while i disengage the lock, even tho i am usually washing my hands before i touch this blade, since it is my precious.
is there a simple way to get this stuff off the g 10 without dissembling the blade? and when it gets dirty enough to the point where i want to take it apart, what can i use as a solvent to clean the dirty g 10?
thanks.
also i feel this blade would be better suited as a tip down, but i can see why its not.
pleeho
Try Ballistol
Post by pleeho »
if that doesn't work, maybe some turpentine?
Handwrecker
Post by Handwrecker »
Try some dish soap. And a sponge or toothbrush. Cleaned my orange Millie up perfectly. And definitely no need to take anything apart, except maybe the clip.
Spider bite
Post by Spider bite »
I clean my g-10 with soap and water.
Frapiscide
Post by Frapiscide »
Just a wet toothbrush or perhaps a schotchbrite pad (blue, of course).
dalstott wrote:When people have no ideas they invent words.
If you can not stun them with brilliance , then
baffle them with BS
dsmegst
Post by dsmegst »
liquid soap and hot water is what I use. An old toothbrush helps for the crevices.
Dan (dsmegst)
:spyder:
:spyder:
Bluntrauma
Post by Bluntrauma »
dsmegst wrote:liquid soap and hot water is what I use. An old toothbrush helps for the crevices.
Same here. Too lazy to type so I quoted.
Sometimes you gotta kick at the darkness until it bleeds daylight.
AKA: Liveitloud on Blade Forums, USN, EDC, Benchmade forums and basically everywhere but here.
liveit_loud on Ebay.
hiredgun
Post by hiredgun »
What others have said, liquid soap, warm water, toothbrush and sometimes I use toothpaste. Gives a minty fresh smell to your knife. :D
You can't display a toad in a fine restaurant like this! Why, the good folks here would go right off the feed!
SpydieZ
Post by SpydieZ »
I thought I heard if you use warm water instead of cold it will fade the g-10? Maybe I was told incorrectly
Post by The Deacon »
+1 on the dish detergent, warm water, and a toothbrush.
SpydieZ wrote:I thought I heard if you use warm water instead of cold it will fade the g-10? Maybe I was told incorrectly
Urban legend.
SQSAR
Post by SQSAR »
After a good cleaning with a mild detergent and a toothbrush, i will sometimes put a hint of miltech on the edges of the G-10 and rub/work it in real well. Kind of gives new life to G-10 when its starts to show its age.
spyderfan123
Post by spyderfan123 »
dzarren wrote:I recently acquired a new manix 2 in orange g 10 and around the cage ball lock on the g 10 theres already a bunch of crap accumulating from my hands rubbing agianst it while i disengage the lock, even tho i am usually washing my hands before i touch this blade, since it is my precious.
thanks.
compressed air pistol+a wet sponge always work!
msierant
Post by msierant »
greetings all,
a soft toothbrush with water only. lightly q-tip some wd-40 and your g10 will look as good as new. works for me all the time. the wd-40 brings it back to life.
