Stainless Steel Handle...
- FissionMailed
I'm looking into getting a Harpy with SS handles as a dress knife, but Im wondering, is there horizontal blade play and what do I do if I develop some? Is it the same as riveted knives? Thanks!
On my SS delica, i had no blade play in either direction. The handles scratch kind of easily though, i don't know if that's an issue for you. You can't adjust a SS knife AFAIK, i don't know about the harpy specifically. I know on my buck 110, i closed it in a thick phone book and hammered in the pivot area to tighten it up.
- The Deacon
The Harpy tends to be tight, at least all of mine are. The combination of a relatively short blade and hawkbill should help keep it that way. They reduce the user's inclination to put a lot of side pressure on the blade. If side play ever develops , treatment is the similar to that for a riveted knife, squeeze the handles together gently, then peen the pin. However, unlike peening a rivet, peening a flush pin will leave your knife looking like ****.
- jujigatame
- Scottie3000
