Recommend a folding utility knife with a STRONG TIP
SnowCrash
Post by SnowCrash »
I'm looking for a knife (aside from my usual spyderco police and benchmade 940 edc's) for heavy duty stuff that I can slightly abuse and not end up with a broken tip- work will be ranging from light carpenter work like getting something out of a wall to possible car accident rescue tasks (ability to cut through tough material while holding an edge)
My current first choice to get is a cold steel recon 1 due to the nutnfancy videos of all the abuse he put it through and still had a like-new blade that was a bit scratched up.
Thanks guys :)
frontline29
Post by frontline29 »
I'd check out a few reviews of the Gayle Bradley.
spoonrobot
Post by spoonrobot »
Pacific Salt.
Samwise
Post by Samwise »
The "holding an edge" bit may not hold up...but the Value line (Tenacious, Resilience, etc.) might be worth looking at.
Spydie Count: :spyder::spyder::spyder::spyder::spyder::spyder::spyder:
Vics: Super Tinker, Farmer
Billy
Post by Billy »
I carried a Delica 2 for almost six years and did things with that knife that just shouldn't be done. I used it as a light pry bar, drywall cutter, wire cutter, screw driver, can opener, etc and the tip survived all that time just fine. From the current Spyderco lineup, I would recommend a Pac Salt or Salt 1 or saber ground E4 or D4 due to their re-designed, thicker tips. Chinook 3 also has a nice sturdy tip, though the blade shape is less than ideal for many EDC tasks. I don't have a whole lot of other non-Spydies, but I do have two ZT 0350's and they are definitely little tanks with premium blade steels (I have satin S30V and Elmax versions), THICK liner locks, heavy duty tips and really solid overall construction.
I LOVE MY MILLIES
ΜΟΛΩΝ ΛΑΒΕ
bohica1998
Post by bohica1998 »
SnowCrash wrote:...work will be ranging from light carpenter work like getting something out of a wall to possible car accident rescue tasks (ability to cut through tough material while holding an edge)
OK, I'm going to be really obvious here and suggest the C-14 Rescue, the C-45 Rescue Jr, or the C-79 Assist. :D
After all, This is the kind of work these models were DESIGNED to do! :eek: :D
AND, if a slightly pointier tip is needed, well, the 2nd and 3rd knives down in the pic below started out the same, it's just that the 3rd one down was slightly modded to give it a bit more of a point. It is still a very strong tip though.
They are: 2003 Rescue, standard Rescue, slightly modded Rescue, and Rescue Jr.
18 :bug-red 's and counting so far... :winking-tongue
Current Inventory: C14SBK Rescue SE - C14SBL Rescue SE - C14PBK Rescue FG PE - C14SBK Rescue FG SE - C10PSGRWBK Endura USN CE Emerson Opener/Black Blade - LBK3HB Ladybug Hawkbill SE - C12SGY Matriarch SE G10 modded - C78PSBK Native 3 SE - C78PBK Native 3 PE - C41SBK Native 4 SE - C41PBBK Native 4 Black Blade PE - C41PSBBK Native 4 Black Blade SE - C77PYL SpyderHawk H1 PE - C106PYL Tasman Salt PE - C122GP Tenacious SE - BY22SBK Meadowlark Hawkbill SE - LGRP3HB USN Ladybug Hawkbill PE - LGRS3HB USN Ladybug Hawkbill SE
yablanowitz
Post by yablanowitz »
Mariner Salt while you can still find them.
dbcad
Post by dbcad »
Hey Snowcrash,
If I'm reading you correctly you're looking for a robust folder that will keep an edge well. I don't know what you mean by tough material, but am leaning towards something CE with a high quality tough steel.
There will always be a sacrifice somewher along the line between really good edge retention and toughness. At some point when trying to pry something out of a wall with a knife you might want to consider a screwdriver or prybar to avoid breaking the tip of the knife.
I would intially look at the Bradley, extremely robust with a wonderful steel that doesn't want to rust when taken care of. Pretty sure the tip would be at least as strong as the Recon 1.
If you want a tough CE look at the Caspian Salt. A Delica CE would also work well.
Look around and see if you find what you're thinking of :)
Charlie
Flash o matic7
Post by Flash o matic7 »
If you're looking for a knife to abuse I would also look into the Byrd line or possibly a tenacious. If your looking to spend a few bucks though I would recommend looking into the Gayle Bradley
Good luck!!!
tonydahose
Post by tonydahose »
bohica1998 wrote:OK, I'm going to be really obvious here and suggest the C-14 Rescue, the C-45 Rescue Jr, or the C-79 Assist. :D
+ 1 on these recommendations. if you are worried about rust go with H1 steel. go with serrated edge too. you won't have to sharpen as often.
WTC #1444 Always Remember
My knives
Spydie count: a few:D
SpydieZ
Post by SpydieZ »
Go out and find a chinook 3 while they are still kindof available. It has the strongest tip of alll my knives!
Joe Internet
Post by Joe Internet »
There's a video on the web of Fred Perrin throwing the CS American Lawman into some wood. Apparently it impressed him.
I'd like to add the Atlantic Salt to bohica1998's list.
SQSAR
Post by SQSAR »
The rescue (both sizes) have got my vote. I purchased one a while back to assist me in my occasional job of breaching physical and infrastructure security measures, and thought the tip would prove strong and useful. It has, and I find it's a good compromise between the more robust tip of the Assist, and the more traditional, yet strong, tip you might find on an Endura.
RDA
Post by RDA »
I'd recommend a Hinderer XM-18 with the Spanto grind based on the tasks you outline.
Regards,
Rich
wsdavies
Post by wsdavies »
The Buck CSAR-T (Combat Search & Rescue Tool) might fit the bill
Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure... than to rank with those poor spirits who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat.
Theodore Roosevelt
yablanowitz
In non-Spyderco knives, try a TL-29. You can use the screwdriver blade to pry to your little heart's content.
LDB
Post by LDB »
Something with a Tanto blade like the Cold Steel or the Buck. You could probably punch it through a car fender and use the serrated section to slice open the fender. As a plus they are one of the coolest looking blades too.
SpaceInvader
Post by SpaceInvader »
For a tip that was made to take abuse, get a CRKT Nealy Pesh Kabz.
yuldeli
Post by yuldeli »
How about a CRKT Folding Razel?
Pneumothorax
Post by Pneumothorax »
Check out the upcoming Spyderdo Breeden Rescue...
___________________________________________
2011: G10 Dragonfly ^ Breeden Rescue ^ Bug ^ Honeybee ^ Centofante 3 ^ Woodcraft Mule ^SFO Visit Buys = Frn Stretch & Native 4 CF!! ^ Salt 1 ^ Burgundy Calypso ZDP-189 ^ Walker Blue Almite ^ Native 5 ^ Squeak ^ Chaparral ^ Urban Olive Green ^ STREET BEAT!!...
2012: Caly Jr (vintage/NIB!), SS Navigator-fave LBK of all time, Jester, Orange Dodo, CS Orange PM2,Techno, Bradley! AIR!!
