Manix 2 owners, pic request/experiment
I feel like i might be stirring the pot here, but honestly that's not my intention, this is just pure innocent curiosity.
I was looking at my Manix 2 today, studying the ball lock and trying to get a good look at how much the ball engages the blade, and i got an idea. If everyone who owns one wouldn't mind posting up pics of their knives in the opened/locked position, and show in the pic how far forward their lock engages the blade...i'd like to see if there's much variance between them.
Without measuring mine, i would guess i have about 3/32 left of "self adjustment" before the plastic cage is totally forward and pressing against the handle. From what i can see, the ball on mine is WAY into the blade...i'd say from the mark on the blade it's a solid 1/16 inch into it. This knife has probably been opened and closed a couple hundred times but is still very much a virgin as far as use goes IMO. I'd especially like to see some well used knives to see how much difference there is in long term use, to see if those balls engage any deeper than mine.
Unfortunately at the moment i only have a cell phone pic but you get the idea.
sharpguitarist
Post by sharpguitarist »
hey david,
here's a pic of mine. not a close up, but you can see the lock.
i'm the second , if not third owner, so i don't know how much it's been opened, plus, it was modified as you can see.
there seems to be less than a 1/16" before the cage will touch the scales/ liners.
later,
don
That's interesting. Are those custom scales? They look thicker, and the lock looks more recessed into the handle than mine does, also looks like the lanyard tube isn't wide enough to meet the sides of the scale.
sharpguitarist
hey d,
this manix was modded by a member here at the forums.
the scales are thicker, so much so that after i received the knife, i had to chamfer the front of the cage opening to get better purchase on the lock. the cage is almost flush with the scales.
the original owner also removed all the jimping around the perimeter of the knife, and reprofiled the handle shape.
this is the only manix i have handled, so i have nothing to compare it to, but i had to have it because of the digicam scales.
i traded for this knife and got a good deal on it, so i'm happy.
i am curious how a unmoddified manix feels in hand, and would like to get a foliage sprint or a black on black.
later,
don
I think the first thing you would notice is the difference in grip shape. The bottom has been modded quite a bit. It's pretty interesting how that one is done though, i'd like to handle it.
Ben_1323
Post by Ben_1323 »
Here's mine, from a post I made in the picture gallery a while back. The ball goes pretty deep.
Post by 5.56 »
Mine were quite different :o
-Rob
Knuckle dragger
Samwise
Post by Samwise »
It's only about a month old, so it hasn't seen that much use yet. Measurement from cage to scale was a smidge over 1/16".
Spydie Count: :spyder::spyder::spyder::spyder::spyder::spyder::spyder:
Vics: Super Tinker, Farmer
npueppke
Post by npueppke »
I used to have one, it engaged about like yours did Evil D, maybe not quite as much.
5.56 wrote:Mine were quite different :o
Wow the bottom one looks like it's bottomed out. Does it have a lot of use or did it come that way?
Post by 5.56 »
Those were both NIB at the time of the picture. The bottom one was near the end of it's travel. Both had some slight blade play, however the bottom one actually seemed a bit tighter with regards to lockup.
-Rob
Knuckle dragger
Lucentdawn
Here's mine
Post by Lucentdawn »
Had it about three weeks.
SaturnNyne
Post by SaturnNyne »
Not the angle you wanted, but I tried to show that in a video a few months ago.
http://www.youtube.com/watch?v=BNiyIsMRK_4
Don't know if it shows well there, but it seems to engage fairly deeply, as they go. I'd say there's about 2mm left between the cage and scales.
"Nothing makes a knife maker-designer feel better than to see their efforts used." -Ed
~ My knives list ~
~ Knife photos ~
JimP
Post by JimP »
Nib.....
jabba359
Post by jabba359 »
Mine engages in the middle of the slot. Locks up great with tons of room for wear. It's interesting how much variation there is, yet it's probably affected by only a few thousands of an inch in tolerances.
Lock Engagement 2.jpg (92.12 KiB) Viewed 3131 times
-Kyle
:bug-red
http://www.spydiewiki.com
gbelleh
Post by gbelleh »
Here is my trio.
There is some slight variance in the seating of the ball, but they all lock up well and operate smoothly.
:bug-red-white
dbcad
Post by dbcad »
Interesting it seems to vary.....
Charlie
ball position.jpg (95.7 KiB) Viewed 3115 times
Charlie
dbcad
Post by dbcad »
I'd love to see The detail production drawings, just to see the tolerance stackup. Of course I realize they're proprietary ;)
Charlie
Charlie
bada61265
Post by bada61265 »
id imagine its possible to get some movement in the back spacer that could change the amount of travel the ball can move up or down.
my knives:
kershaw Leek Buck 119 Cold Steel Recon tanto
Cold Steel Ti Lite VI ,
Spyderco: Tenacious ,Persistence, Endura 4 blue Stretch zdp blue, Manix 2 ,Native s30v . Sage2 titanium, Gayle Bradly cpm m4, Muleteam mt 10, woodcraft mule s30v. Orange Delica 4
Bark River PSK 154cm, Gunny, Bravo 2, Canadian Special
JNewell
Post by JNewell »
Deeper is better with this lock, IIRC from the results posted a while back. I have been unable to induce wear in a reasonably-cared-for Manix 2 CBL, but I did not try to simulate use in, say, the Iraq desert.
