Mule in S90V
ricklee4570
Mule in S90V
Post by ricklee4570 »
Incredible knife! I really like the cutting power.
Im getting ready to sharpen it for the first time. What do you guys recommend I use (diamond stones?)?
What angle is recommended for a light use knife with this steel? (I wont be doing any chopping or hacking)
mrsteel
Post by mrsteel »
Is it a PE or SE???
ricklee4570
Plain edge, I didnt know they made the Mule in serrated edge.
SaturnNyne
Post by SaturnNyne »
ricklee4570 wrote:Plain edge, I didnt know they made the Mule in serrated edge.
They didn't.
"Nothing makes a knife maker-designer feel better than to see their efforts used." -Ed
~ My knives list ~
~ Knife photos ~
ChapmanPreferred
Post by ChapmanPreferred »
What sharpening equipment do you have available? I keep my S90V knives at 30 degrees inclusive on my Sharpmaker. I usually start with diamonds and then progress through to the fine rods.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
ricklee4570
I have an Apex and a DMT Aligner.
chuck_roxas45
Post by chuck_roxas45 »
ricklee4570 wrote:I have an Apex and a DMT Aligner.
I'm sure any of those could handle the S90V mule. The edge pro would probably give you more accurate bevel angles. If you use the polish tapes you'd get a mirrored edge as well.
ricklee4570
I heard through another forum that nothing but diamonds works on the S90V.
dsmegst
Post by dsmegst »
ricklee4570 wrote:I heard through another forum that nothing but diamonds works on the S90V.
That's nonsense. I used paper wheels with Silicone Carbide and Aluminum Oxide grit that's glued onto the wheel to reprofile, followed by the polishing wheel using white polishing compound (Jacksonlea C-5). ;) No diamonds were used.
I love mine at 20 degrees inclusive. :D
Dan (dsmegst)
:spyder:
:spyder:
ricklee4570
Thanks for the information!
JNewell
Post by JNewell »
dsmegst wrote:That's nonsense. I used paper wheels with Silicone Carbide and Aluminum Oxide grit that's glued onto the wheel to reprofile, followed by the polishing wheel using white polishing compound (Jacksonlea C-5). ;) No diamonds were used.
Agree re: nonsense. I have successfully sharpened the Military, Manix 2 and Mule on the Sharpmaker.
