What's you Sharpest User...............
What's your sharpest user? Mine would have to be my RJ Martin Overkill.....
It came scary sharp and still is after 1 touchup on the Sharpmaker.
- The Deacon
In folders, my Jigged Bone Kiwi with the Tom Krein full flat grind treatment would be the wickedest slicer I own.
- tonydahose
my Krein'd jess horn sprint with zdp
WTC #1444 Always Remember
My knives
Spydie count: a few:D
My knives
My black ZDP Caly Jr.
Touch the blade to your skin & you're bleeding.
Can i just say whatever knife happens to be in my pocket at the time? :D
That is the goal anyway. I have this oddball Beretta folder...i'm not sure what the steel is and all it says is Japan on the blade, but that thing takes an edge like nothing i've ever owned...i never carry or use it though.
- Pharmagator
- CanisMajor
- vampyrewolf
as freshly sharpened or after a month of use? :p
Freshly sharpened I'd put my s30v lil temp up against my zdp caly jr... after a month of use, my lil temp is still gonna be sharp while the zdp is gonna need a touchup. Both done at ~30 degrees.
I've got my ss 'fly down to ~12 degrees, and while I can get it hair popping sharp easily, the ats-55 isn't great at holding that edge... though it'll stay sharp for a few months.
Coffee before Conciousness
- defenestrate
MY Grasshopper is actually probably the sharpest, all in all. The edge may not last forever, but WOW, what a slicer until it does wear down! I assume that the thin blade, FFG and type of blade steel all are factors here - and the fact that it is easier to get a consistently ridiculous edge certainly doesn't hurt! Just a few quick passes on the SM204 and it's back the way I like it. I usually just take it to work as it as very inconspicuous and handles anything I might want to cut under those conditions.
