Ultrasonic Cleaner for cleaning EDC items - PART 2
PolishSumgai
Post by PolishSumgai »
ultrasonic cleaner - PART II
I learned a valuable lesson today as I went to read the post I wrote
on which types of stains and discolorations can be removed with an
ultrasonic cleaner versus types that can't. I found the post to be
essentially unintelligible! It could easily be the worst written
post I have posted yet. At least I hope so. For this I feel
embarrassed and I apologize to many of you who have appreciated most
of my efforts in the past and tried to follow this particular piece.
I assure you that this does not represent that I have lost it
altogether. I made the horrible error of trying to write something
while I was in fact falling asleep at the keyboard. It was a
question that I was eager to address, but I now realize that there
is no question that is so important to address that it can't wait
until morning. In a much more concise way, I think I can condense
what I was trying to say into a single lucid paragraph. Vintage
plastic pens, almost all of which are made from Pyroxylin, are
relatively porous materials. In these plastics, discoloration falls
into 2 categories. One type is when the stain or discoloration IS
NOT chemically bound to the plastic. These, which are most commonly
due to inks, can be removed in principle with the aid of an
ultrasonic cleaner. The other type of discoloration is when stain IS
chemically bound to the plastic. This can occur under a number of
conditions including heat, light, and exposure to reactive agents
such as fumes from rubber sacs and some types of inks. This type of
stain or discoloration cannot be removed from the plastic
essentially because the discoloration has become an integral part of
the plastic itself. Unfortunately, this type of discoloration occurs
frequently in many colors and patterns that are highly desirable,
such as jade, pearl, onyx and lapis among others. Even pure
colorless Pyroxylin becomes ambered, an irreversible reaction that
is induced by exposure to light, heat and chemical reactants. ALAN
There is at least one factor alone that could explain the
difference. That would be the efficiency of the wave generator. As
even 40 watts for an appliance that is only used minutes at a time
is almost negligible, there isn't much incentive to design and
produce an efficient unit. For a company like Bronson, who
essentially makes nothing but UC's up to tanks that hold many tens
of gallons, there is an incentive for more efficient design. In
short they may just have the engineering in place to make an
efficient unit without having to invest much effort in it. Another
factor would be in the difference in the frequency of the waves
generated. In principle, 60 KHz would be preferable than 40 KHz and
this would take more power to generate. But once again, efficiency
is a big question mark. A good analogy is to compare a 60 watt light
bulb to a 40 watt bulb. If we define that the watts pertain only to
incandescent bulbs than the 60 watt bulb produces more light at the
filament. But this begs two questions. One is how far away from the
incandescent bulb you are. If you are 10 feet from the 40 watt bulb
and 50 feet from the 60 watt bulb, which is going to look brighter?
This speaks to how efficiently the energy generated is directed into
the system. The other question is what happens when the bulbs are
not constrained to be incandescent? This is what I was primarily
referring to above. Obviously a 40 watt fluorescent bulb will
generate far more light at the source than a 60 watt incandescent
bulb. This is the kind of thing I was referring to when speaking of
the efficiency of the generator used. I can't say for certain that
your small Bronson unit will be better or worse than the units I
found. All I can say is that I know from experience that Bronson
makes quality UC's in general. It would be good to come up with some
standard by which we could compare the units directly. Perhaps the
time needed to remove the stain made by a particular ink on a given
surface. I suspect you will be happy with the Bronson UC, unless
there has been some big changes in the company since I bought my
last unit from them 10 years ago. This was their smallest
thermostated unit at the time. I believe it had a half-gallon tank
and sold for over $500. ALAN
Before I had a Bronson ( Branson is the correct
name of the UC (note ALAN refers to it as a BRONSON) )UC in every
lab I worked in. They are indeed the largest manufacturers of UC's
that I am aware of. In fact, when I first decided to by one for my
pen work, I contacted the regional Bronson dealer. At the time, at
least according to him, they didn't have one in the $100 to $200
price range as the smallest model was significantly larger. I would
think that if they now have one in this size and price range it
would be an excellent alternative to the ones I mentioned. I would
also recommend posting this information on the Zoss list, if you
haven't already, and you may certainly cite my recommendation of
Bronson.
Several years ago I posted a question on the net asking for sources for a
good, powerful and reasonably-priced Ultrasonic Cleaner (UC). I
received a few suggestions that were worth following up. The
suggestion that I got from Marc Brown I believe was THE answer. He
told me about a small, powerful unit made by Koh-I-Noor,
specifically for cleaning Rapidograph technical pens that use
pigmented ink. I ended up buying the unit from the source he
suggested, the Re-Print Corp. for $112 (list is $135). This unit has
a round stainless steel tank that measures approx. 3 5/8" in
diameter and 2" high - very small size. I am used to laboratory
units 5 - 10 times more costly. This unit, for it's size is every bit as powerful.
My first test was a Parker fountain pen that seemed to be clogged
with India ink. Placed in the unit, the crud started shooting out
both ends immediately. The section was completely clear in minutes.
A good way to check the power of a UC is to put in cold tap water.
The power of the Ultrasonic waves should heat the water to warm in
about 10 minutes. This unit passed this test with flying colors.
Even though the unit is shallow, It is possible to clean long
objects by placing them in a along with the cleaning solution in a
plastic container and placing this container in the tank, which
would then contain tap water only. This is actually a very efficient
way to use any UC as only as much cleaning solution as needed is
used. For cleaning purposes 409 to water, about one to one is about
right for very stubborn jobs, while much more dilute detergent, or
even no detergent at all will suffice for easier jobs. Dilute
ammonia can also be used but it is ill-advised in a room that is not
adequately ventilated. ALAN
Rather than posting info on solutions used to clean pen, nibs,
parts, etc. the winner for cleaning solution to use in your UC tank
is a 50/50 mix of water and 409 cleaner. It should be noted that
certain items should not be cleaned in a UC. I am sure there will be
posts covering the specifics as the tread develops.
Based on all the info presented and reading the tech specs as well
as ALAN's love for Bronson's that is what I purchased off the
Internet. I later sold it and acquired a Koh-I-Nor which has a
smaller capacity but is a far superior machine when it comes to
cleaning small parts. Recently I sold the Koh-I-Nor and purchase a
UC from Harbor Freight for $50 which is a good size for MTs.
Listed below are the sources for UC's .
http://www.micromark.com/ULTRASONIC-CLEANER,8024.html
http://www.harborfreight.com/cpi/ctaf/C ... goryID=774
http://www.bransonic.com/
http://www.cleanosonic.com/
http://www.sonicsonline.com/gemoro-ultr ... eaner.html
Use "ultrasonic" in the search engine in each of the above sites to
locate the cleaners. I hope this helps all that are looking for a
ultrasonic cleaner
UC FAQ - http://www.coleparmer.com/techinfo/tech ... htm&ID=792
EODtech
12/24/2002 - original review
9/29/2009 - updated
To the living we owe respect, but to the dead we owe only the truth.
Voltaire
[SIGPIC]<img src="http://i717.photobucket.com/albums/ww17 ... allest.jpg">[/SIGPIC]
Get rid of that nickel plated sissy pistol and get yourself a Glock.
psimonl
Post by psimonl »
Still.... Please a short version!!!!
Simon
"Everyday above the ground and vertical is a good day".
-Sir A. Hopkins in "The world's Fastest Indian"
"If it hurts, it means you're not dead..."
-Kayakist Marie-Pier Cote
The Spyderco Cookbook
65535
Post by 65535 »
A quality ultrasonic cleaner might just clean all that gunk of your knife easier than anything else. :p
asfaltpiloot
Post by asfaltpiloot »
Hi.
Are also a member of SOSAK (Secret Order of Swiss Army Knives)?
http://www.sosakonline.com/index.php?op ... &Itemid=35
Robert
"Never leave home without a knife,
one day it may save a life"
