more compression lock models wouldn't hurt either Spyderco
G10 STRETCH GIVE IT TO US! :spyder: :spyder: :spyder:
Any lock which favors operation by one hand over operation by the other. Locks where the unlocking action is from side to side inherently do that. The compression lock is such a lock, as are conventional framelocks and liner locks. That is not to say they cannot be operated with the other hand, just that it will be more difficult, less convenient, or require a less safe hand position. There are those who will argue this but, if that were not the case, you would see more knives where those locks operate in the opposite direction. In the case of the compression lock, Spyderco did make one which worked that way, the Gunting. A common complaint from right handed users and perhaps one reason the Gunting failed in the marketplace, was that the lock was wrong handed.Scottie3000 wrote:What do you mean by "handed" lock?
You are, of course, entitled to your opinion. To some extent, issues like this are mostly a matter of opinion. However, in rebuttal to your theory, I would only ask if that is true, then why has Spyderco very obviously chosen not to build another compression lock which operates that way? Right handers comprise between 85% and 90% of the population, yet every single compression lock before and since the Gunting has operated in the opposite direction from it. For those not familar with them, that's the Vesuvius, Lil Temp, both versions of the ATR, both versions of the Salsa, the compression lock prototype of the Ocelot, the ParaMilitary, Yojimbo, "S", and Superhawk. I'd be willing to bet that, when the compression lock version of the Sage comes out, it too will work as those do, not as the Gunting did. As much influence as Mrs. Glesser has, I don't really think that choice has been an effort to favor those of us who are among her fellow southpaws.yablanowitz wrote:Personally, I think the Gunting is the only right-handed compression lock they've made. The commercial failure of the Gunting had more to do with being an over-specialized weapon than the handedness of the lock. It may have been great for what it was intended for, but that particular market is/was tiny in the grand scheme.
As for the Stretch II, G-10 would be okay, but leave the lock alone. If you must change something, take the hump off its nose.![]()
Exactly, but, as a lefty, I find it much easier to use the thumb of my left hand than the index finger of my right hand. Because of this, I consider the compression lock (in the standard implementation) to be left-handed, and am still puzzled why some right-handers are so enamored of it :confused:powderkid wrote:Right handers use their index finger, lefties use their thumbs?
Junior avatar courtesy of dialexSequimite wrote:I use knives. I collect experiences.
I'm an admirer of Spyderco's designs. Using them is like immersing yourself in music or studying a painting in a museum. I buy some "fine" art but my preference is for usable art.
When I got my Para-Military I quickly realized that it would work better for a lefty then for a right handed person. In fact I would usually close it and open it with my left hand because it was easier.catamount wrote:Exactly, but, as a lefty, I find it much easier to use the thumb of my left hand than the index finger of my right hand. Because of this, I consider the compression lock (in the standard implementation) to be left-handed, and am still puzzled why some right-handers are so enamored of it :confused:
I agree with Deacon on the handedness of the compression lock. It's easier for me to use the right side Gunting compression lock than it is to operate a left side liner lock, but both locks definitely favor one hand over the other. That's one reason I didn't care for the Gunting.The Deacon wrote:I would only ask if that is true, then why has Spyderco very obviously chosen not to build another compression lock which operates that way?
I know you're not the only one who feels that way. Bram Frank obviously did, which is why the Gunting was built that way.
