Blade centering on new orange Military
JediKnight86
Post by JediKnight86 »
Grrr. I wait all this time for the orange Military, order it the second it's available, and it arrives with a jilted blade! :mad:
It's slanted toward the lock side. Loosening the blade seems to be the only quick fix but then there's blade play. Help :confused:
Hi my name is Alex and I'm a Spyderholic :D
brandonreed2008
Post by brandonreed2008 »
JediKnight86 wrote:Grrr. I wait all this time for the orange Military, order it the second it's available, and it arrives with a jilted blade! :mad:
is it actually contacting any part of the handle when closed? if not it should be fine.
War is mostly waiting.
LowTEC
Post by LowTEC »
you shouldn't loosen the blade.
instead, tighten the pivot to very tight, then loosen the back spacer screws, press the blade to the opposite side and wedge the blade with paper and let it stay like that when closed. then tighten up the rest of the screws, take the paper out and see the centering again, when desired result is reach, adjust the pivot back to normal tightness, problem fixed. I have 9/10 of all my :spyder: NOT center when close and I use a few different methods to fix all of them, and this is the one for millie and para :D Good luck
LBK3S|C52BK|C106PYL|745|943|C08CFS|C52m|C36GPBK|C10GPFG|1003UBK2|14210|C123CFP|C81FG
C28WH|1600DAM|C105|RC4S|C51GPFG|1735OR|830675|C90CF|C123TIP|CS97KMS|BRKT-CS|BRKT-MC
BRKT-LC3V|C101XHP
JediKnight86
brandonreed2008 wrote:is it actually contacting any part of the handle when closed? if not it should be fine.
No it's not touching. It just bothers me. All my other recent Military's were perfect.
Eazy_tom
Post by Eazy_tom »
At least you got yours.
I ordered one from your corner store and they say:
"Best best for when this order may ship: 06/30/2009"
:mad:
JediKnight86
LowTEC wrote:you shouldn't loosen the blade.
Cool. I'll try it! Thanks!
Eazy_tom wrote:At least you got yours.
:mad:
Oh wow. I would just cancel and find one on eBay. I didn't pre-order mine, just happened to be on knifeworks.com just after it was posted. I don't think you're the only one waiting on an order.
brandonreed2008
:mad:
you can just forget about it completely and then in a couple of months be very surprised when a package mysteriously shows up on your doorstep hah..
JediKnight86
LowTEC! It worked!!! Thanks bro :D
LowTEC
Post by LowTEC »
JediKnight86 wrote:LowTEC! It worked!!! Thanks bro :D
Not a problem, enjoy your blade!
BRKT-LC3V|C101XHP
imatyssik
Post by imatyssik »
LowTEC, while you are at it can you post some sort of tutorial for other Spyderco models that you know how to fix centering on. I have no issues with my knifes but it could be handy in the future. Thank you in advance.
uncle edge
Post by uncle edge »
OMG, My 1st and only Military arrived the same exact way that JK`s did, blade slanted towards the lock side. I was bummed since I recall reading that it may not be fixed for this reason if I sent it in.
I googled Military blade centering and this thread came up! Tried it, worked PERFECT! Many thanks Low-Tec!
Question is, does everyone have to do this centering trick?
I am one excited and happy camper right now!!! My Millie is all better!!!
Toad310
Post by Toad310 »
:mad:
I got one Friday. Just look around.
tkdman41
Post by tkdman41 »
uncle edge wrote:Question is, does everyone have to do this centering trick?
Nope. Got my orange millie in person from the SFO and its perfect although somehow I managed to get black gunk on the top of the handle that won't come off.
Endura ZDP-189 CE | Endura Wave CE | Salt 1 PE | Centofante 3 PE | Tenacious PE | Tenacious SE | MT02 Second | MT03 | JD Smith | Caly 3 ZDP-189 CF | Bill Moran | Military | Tasman PE | Stretch 2 CF | Endura | Delica | Dragon Fly
JspyEDC
Post by JspyEDC »
Great technique, worked on my Para. Thank You.
Spyderco Collector #162
Fred Sanford
Post by Fred Sanford »
Funny thing is I do something a little different but it works. I read it on this forum or Bladeforums at some point in the last 4 years.
I back the pivot off about 3 turns until the blade has a bit of play. Then I open knife and let it lock. Then I lay the blade flat on a table with the handle sticking off of the table. I then hold the blade down with my hand so it cannot come off the table or move, and then I push the handle towards the lock. After that I tighten the pivot all the way down until the blade will not move. Then I back the screw off until it's where I like it. I then close the knife to find the blade centered. Weird. I have no idea how/why it works.
LowTEC
Post by LowTEC »
I feel safe that I'm not the only anal in the world that get annoyed by the blade centering :p
BRKT-LC3V|C101XHP
LowTEC
Post by LowTEC »
I feel safe that I'm not the only anal in the world that get annoyed by the blade centering. :p
imatyssik: I feel too busy/lazy to do some write ups but I'm willing to share my experience if anyone else really want to fix theirs. I will check back on this thread every once awhile.
David Lowry: glad your method works for you. No offense but I find pressing on an open blade with my hand and pushing the handle with my other hand is kinda......
Plus, you might need to loosen, tighten, open and close the screws/the blade a few times or start all over before you get the desired position. I have tried similar method but with the blade closed, it didn't work for me :o But it's fun to play with it nonetheless
BRKT-LC3V|C101XHP
Mako109
Post by Mako109 »
LowTEC -
I have full size MANIX that had a misaligned blade which had maligned the harmonic balance of my Spyderco obsession. The weight of that imperfection on something so nearly perfect, weighed on me greatly. So, I could not help but to attempt your blade alignment procedure.
It worked...beautifully. My Manix blade is now aligned!!! And my harmonic balance for all things Spyderco has been restored.
If there were an award for Tip of the Year, I think you deserve it.
Thank you for straightening us out... :)
SecSpyral
Post by SecSpyral »
Mako109 wrote:Thank you for straightening us out... :)
O Lets let the Puns ROLL! ;)
amen74
Post by amen74 »
Great topic. An uncentered blade annoys the heck out of me.
Aaron
Current EDCs: Golden models
:spyder: FG D2 Military:cool: Orange UKPK:spyder:
NEXT: Rock Lobster, Manix2, TiMil
