Torx screw size?
ScanDgrind
Torx screw size?
Post by ScanDgrind »
Hi folks,
This is my first post on the Spyderco forum. All I can say is 'what a great place for everything Spyderco'.
Now, to my question. Does anyone know what torx size the screws are on the Mini Manix pocket clip please?
I've just recieved a new Mini Manix and I'd like to swap the pocket clip around for tip up carry but I don't seem to have the right sized torx for the pocket clip screws. I just wanted to check before I go out and by myself a set of torx only to find the size I need isn't included in the set.
Thanks in advance.
Take care,
Tony
PSU
Post by PSU »
The clip on the Mini Manix takes a T9. A T8 will work too but it will be slightly loose.
Welcome to the forum!
People say, oh it's dangerous to keep weapons in the home, or the workplace. Well I say, it's better to be hurt by someone you know, accidentally, than by a stranger, on purpose. - Dwight The Office
It's okay for me to talk about my job, as long as I'm not specific. I am the Sergeant of a three-man Rapid Tactical Force at one of America's largest indoor retail shopping areas. - Gecko_45
The more you learn about knives, the better Spyderco looks. - Sal
TazKristi
Post by TazKristi »
Tony,
Welcome to the Spyderco Forums. We hope you enjoy your time with us.
Kristi
Post by The Deacon »
PSU wrote:The clip on the Mini Manix takes a T9. A T8 will work too but it will be slightly loose.
Can't be certain, since both my Manix and Mini Manix are older versions with Phillips head screws, but I'd be rather surprised if that's true. The Torx screws on every Spyderco three screw clip I've ever encountered which used them were T-6. Think you're thinking of the Torx screw for the models which use a wire clip.
wescobts
Post by wescobts »
Welcome to the forum, I do not know the answer to your question, but somebody will.
learning it the hard way... :rolleyes:
cyberspyder
Post by cyberspyder »
It's a T9. I just took apart my Manix.
I BLEED TOXIC GREEN
:spyder: SPYDIE NUT
:spyder:
:spyder: Spyderco OG Manix PE
:spyder: Spyderco Black Dodo SE *gone*
:spyder: Spyderco Black Paramilitary PE *gone*
:spyder: Spyderco SPOT PE *gone*
:spyder: Spyderco OG Blackhawk SE *gone*
:spyder: Spyderco Ladybug/Photon *gone*
cyberspyder wrote:It's a T9. I just took apart my Manix.
Are you talking about the clip screws, or the pivot?
PSU
Post by PSU »
The Deacon wrote:Are you talking about the clip screws, or the pivot?
All of the screw heads are the same size on the latest Mini Manix.
cyberspyder
Yes, on both the Manix and the Mini-Manix, all the screws are the same (or at least use the same Torx bit).
I BLEED TOXIC GREEN
:spyder: SPYDIE NUT
:spyder:
PSU wrote:All of the screw heads are the same size on the latest Mini Manix.
cyberspyder wrote:Yes, on both the Manix and the Mini-Manix, all the screws are the same (or at least use the same Torx bit).
Wow, that's surprising, although I'm not sure why, since change seems to be the only constant where :spyder: is concerned. :o :D
Murdoc
Post by Murdoc »
Proof here.
I have to check my Mini Manix when I get home :)
Dennis
Murdoc wrote:Proof here.
Dennis
Well, I've already been convinced that I was wrong, and it's a really nice picture, but either those knives have the ultra-new fully transparent clip and clip screws, or it really doesn't prove anything.
Murdoc
Post by Murdoc »
:D :D
Ok you got me :)
All I was wanting to show with this nice pic (not mine) was that screw heads with different diameter feature apparently the same Torx bit size in the handle and pivot; that's something I never actually noticed on my Mini Manix; on the Spydies I remember disassembling, the pivot screws always were bigger than the handle screws.
It would be nice to see the other side with the clips (unless, as you guessed, these Manixes are equipped with leftie invisible ones ;) )
Dennis
Shike
Post by Shike »
ScanDgrind wrote:Hi folks,
Thanks in advance.
Take care,
Tony
Welcome and do yourself a favor, visit Home Depot and get one of these
http://www.homedepot.com/webapp/wcs/sto ... 401+502868
They also have the flat and Phillips that other knives might use.
Regards
Shike
HWnut
Post by HWnut »
Sorry for necrophilia, but I want to know the size of the Torx screw that is needed to screw off the clip on the new Endura 4 and Delica 4 with FFG and colored handles?
Thanks for answer! :)
Simsmac
Post by Simsmac »
HWnut wrote:Sorry for necrophilia, but I want to know the size of the Torx screw that is needed to screw off the clip on the new Endura 4 and Delica 4 with FFG and colored handles?
It's a T6, I believe. Also, "necrophilia" is most definitely not the word you were looking for... ;)
spyderholic
Post by spyderholic »
hi and welcome to the forum tony.
jim.
:spyder: bug, urban wharncliffe, endura 4 pe, ukpk frn drop point pe, matriarch sprint run pe,
aka jim410 over on BB. :D
HWnut
Post by HWnut »
@sim
Maybe forum necromancy is better? :D
And thanks for the answer. Will have to buy a T6 torx then.
@jim
thanks, but I'm another HWnut. ;)
Simsmac
Post by Simsmac »
HWnut wrote:@sim
I heartily agree, on both matters. :) I suggest getting a Kershaw T-Tool if you only need a T6 (also comes with a small phillips bit and a T8), because it's only about $5.
HWnut wrote:@jim
I think he was referring to the OP of this thread, who seems to have only posted this single thread two years ago, and then been in lurk-mode for the past two years... Or just abandoned the forum. :rolleyes: Anyway, a welcome to you. :) Hopefully you'll stay longer than Tony...
HWnut
Post by HWnut »
Simsmac wrote:I heartily agree, on both matters. :) I suggest getting a Kershaw T-Tool if you only need a T6 (also comes with a small phillips bit and a T8), because it's only about $5.
Will have a look on this one if my tool shop around the corner does not sell me a T6 well below that $5. :)
Simsmac wrote: I think he was referring to the OP of this thread, who seems to have only posted this single thread two years ago, and then been in lurk-mode for the past two years... Or just abandoned the forum. :rolleyes: Anyway, a welcome to you. :) Hopefully you'll stay longer than Tony...
Oh you are right again. I just saw his UK location and thought he would be on the same air gun forum as me, there are other HWnut's, thought he meant one from there. :D
Hopefully I stay longer. Today I got my first Spyderco. The Spyderco Endura 4 FFG with gray handle. As soon as I unpacked it I was totally impressed. The next thing was that I reconized they offer a smaller version the Delica. I ordered my second Spyerco immediately (Delica 4 with brown handle) on the same day I got my first LOL. I hope this doesn't get me addicted... :D
