I keep hearing people say that spydies with a backlock develop vertical blade play :eek:
Is that true?
Has that happened to anyone here?
It's never happened to me I'm just wondering.
And my second question is to delica collectors:
I have a few different d4s and it feels like out of all of them my g10 d4 has the lowest tolerance and the strongest construction but it does a weigh more than the others.
If you had to choose between all the delicas out which would you say is the best and why?
Vertical blade play and Delica questions
Wow, so many questions..... let's see:
Blade play: None of my Delica's have any blade play in any direction whatsoever. Then again I don't use them very hard. I would say that if they are used hard and abused then blade play in the vertical direction might be from battoning? and sideways play from twisting or prying ?
Out of all my Delica 4's. They are all pretty much the same with the exception of the ZDP189 version which has obviously a different bladesteel.
If you are talking about the Delica 5 (I am a naughty boy, but I still think the G10 PLUS the FFG on this baby makes it different enough :p ) then the construction is probably a bit tougher. It certainly is heavier. It probably looks a bit nicer. I think the exposed full liners give it a bit more fancy schmancy look. Grippy G10 lends an air of solidity. And the FFG on the blade seems to help in its cutting prowess.
On a subjective note: Some people don't like the look of FFG blades because it doesn't show any nice grind lines. Some prefer the FFG because of its utilitarian quality of perceivably better cutting ability.
I choose each one of my Delicas for different tasks. And thus cannot choose to say which is better or not without a qualifier :D
Cheers
in my limited experience with backlocks I have discovered that all of them already have or will develop vertical bladeplay (meaning that if I grab near the tip of the knife and shake it on the vertical it will move). I guess this is the nature of the beast, that's why I generally prefer frame/liner/compression locks
on the other hand, the only Spyderco backlocks I own are 2 frn enduras/pacific salts, but this also applies to other brands (the SOG twitch comes to mind)
ALL of my 20+ lock backs have some up and down play
I still hate it :eek: but I'm slowly starting to learn to live with it :p
I recently got a NIB Delica1/SE in AUS8 and I like this one the best so far closely followed by my (almost) flawless black Delica 4/SE
....AND A FG(PARA) MILITARY/SE IN CPMD2(thanx Sal)
caly3 is my first to notice after messing with it and not even carrying it it went from perfect to some blade play up and down, maybe it had it already but i never noticed it though.
delica question...
D4 FRN CE for me all the way
its light, smooth, the clip holds on your pocket just perfect.
I havent found a knife that can replace the qualities of the d4!!!
delica question...
It has always been my understanding and experience that back locks inherently have a very slight amount of vertical play (especially those with FRN handles) due to their design. Many do not usually consider this an issue unless the amount of play is excessive. I would imagine the G10 Delica would have the least amount of noticeable play due to its design. I don't have one, but I do have a Police 3 on the way and I'm curious to see how tight the tolerances are on a back lock with G10 handles and full steel liners.
Jason
- araneae
Several of my spydies have slight amounts of vertical movement. This should not however affect the security of their locks. My Gen 1 Delicas have less movement than my D4s.
-Nick
Last in: N5 Magnacut
-Nick
My Delica 4 (Waved) has ZERO side-side play. It has some flex, but when I move it side-side, I cannot detect any difference in space from the tang to each FRN scale (the space between).
Vertical, however... Would you consider this vertical blade play?
If I put my hand on the handle as if I were going to use the knife (with the thumb on the thumb ramp), and then put my pinky through the spyderhole with my other hand and tug, I can feel a small amount of difference under my thumb (which is also touching the backlock). If that's vertical play, then I believe I have some of that.
I think the reason is because the lock isn't flush with the tang and FRN. If I look very closely, I can see that the lock isn't all the way down; there is a small amount of lock sticking up in relationship to the FRN.
It doesn't seem to affect the usability of the knife, in any case. The D4 has been great to me for a little over a month now (the time I've had it). I love it more than any of my other knives (which aren't many, though).
