I personally prefer permentaly attaching the scales with pins, but I know some of you dont so here we go.
This is a standard 1/8" barrel pivot with screws. Avaiable at from most knife making supply stores. They cost $2-4 a peice depending on where you get them and if they are tempered. I prefer the tempered ones. I love these barrel pivots and wanted to use them. So what I did with lathe a small very thin walled sleeve that presses inside the blade that the pivot will as well press into. So when it all works out scales can be screwed to the blade. They are then removeable and can be switched between knives.
Here are some photos with Hunter Orange G-10 scales with a custom texture. Let me know what you all think. Shoot some ideas at me as well if you have a better solution cause those sleeves arnt easy to make.
