CE SS Cara Cara question
haxxor
Post by haxxor »
Is the plain edged portion double "v" ground, or does it have a chisel grind? :confused:
Left Hand Path
Post by Left Hand Path »
I am pretty sure the CE SS Cara Cara will have a chisel grind on the PE portion. The FRN Meadowlark is like this as well. I believe the CE Crow/Raven have V-grinds on the PE portion, but the other byrds are all chisel grinds for CE.
Perhaps someone else can confirm.
-Nick
Join Today!
http://www.KnifeRights.org
JBE
Post by JBE »
I had asked this same question some time back and I believe the replies indicated that all CE Byrds are chisel ground on the PE portion.
Jason
Left Hand Path
JBE - I think you are right with the possible exception of the Crow.
I don't have one, but I am sure I saw a picture of a CE Crow somewhere and it was clearly a V-grind on the PE portion.
Maybe someone has one and can confirm?
One of the reasons I like CE Spydercos so much is because of the V-grind on the PE portion.
-Nick
Join Today!
araneae
Post by araneae »
Left Hand Path wrote:JBE - I think you are right with the possible exception of the Crow.
You are correct, CE Crows/Ravens have V grinds.
-Nick
Last in: N5 Magnacut
haxxor
Post by haxxor »
:) Thanks for the replies. I guess the SS CE CaraCara is on my list :spyder:
ghostrider
Post by ghostrider »
I have one of the original CE Cara Cara's, and it is chisel ground. I also had a FRN Endura CE (now called Endura 3) that was chisel ground. Both knives were chisel ground in both SE and PE portions of the edge. I have heard others say that their CE Enduras were "V" ground on the PE sections of the blade, so who knowes.
[INDENT]
Thread for tying tips:
Avatar provided by DAYWALKER
