Rescue 93MM PE question
Is the plain edged rescue 93MM hollow ground?
- Michael Cook
- The Deacon
Between the older Rescues (which are the only ones you can find in PE) and the Atlantic, I'd lean toward the Atlantic for the better choil and jimping.
The current VG-10 Rescues are flat saber ground.
http://spyderco.com/catalog/details.php?product=12
The PEs on Deacon's page look to be that way as well.
If you want hollow saber grind, that leaves the Atlantic.
Tom
__________________________________
[url]http://spydercovt.com[/URL]
Junior avatar courtesy of dialexSequimite wrote:I use knives. I collect experiences.
I'm an admirer of Spyderco's designs. Using them is like immersing yourself in music or studying a painting in a museum. I buy some "fine" art but my preference is for usable art.
Golden oldies
The old Mariner was more or less the predecessor of what we know now as the Rescue model. If you would be lucky enough to find one of them in a plain edge that would be a good one to have. There was knife show here in Missouri about a year ago and an exhibitor there had 2 used ones for $40 each and I'm really kicking myself for not getting them.
If I remember right I think there are 2 of 3 of them on Deacon's knife website. Now I don't know if they ever made the STainless Rescue model in PE or not. I've never seen one though.
I concur.The Deacon wrote:Between the older Rescues (which are the only ones you can find in PE) and the Atlantic, I'd lean toward the Atlantic for the better choil and jimping.
The choil (and consequently the ergonomics) on the Atlantic Salt is far superior to that of an older rescue.
People say, oh it's dangerous to keep weapons in the home, or the workplace. Well I say, it's better to be hurt by someone you know, accidentally, than by a stranger, on purpose. - Dwight The Office
It's okay for me to talk about my job, as long as I'm not specific. I am the Sergeant of a three-man Rapid Tactical Force at one of America's largest indoor retail shopping areas. - Gecko_45
The more you learn about knives, the better Spyderco looks. - Sal
- The Deacon
For the record, I just checked and the PE version of the older ATS-55 FRN Rescue is hollow ground while, as you noted, the VG-10 one is not.catamount wrote:The current VG-10 Rescues are flat saber ground.
Unless it was another very limited production Japan market deal, like the PE/G-10 Civilian, they did not.JD Spydo wrote:Now I don't know if they ever made the STainless Rescue model in PE or not. I've never seen one though.
My one complaint with my PE atlantic salt is the choilPSU wrote:I concur.
- The Deacon
Good point Pete, what works for me, or anyone else, may not work for you. There are few, if any, absolutes in that regard. Each of us can only say what we personally like, or don't like, and why.Pete1977 wrote:My one complaint with my PE atlantic salt is the choil. I cut a lot of rope with it and I find that sometimes smaller diameter line (less than one inch) tends to hang up in it.
It's mainly due to the way I cut rope, especially when I was lobstering. I bend the rope to be cut back on itself, put the blade in the bight, and either push away from me with the edge outboard, or pull upwards with the edge turned up. When I'm going fast, or the boat was pitching, I tended to catch the rope in the choil and when wearing slippery gloves there was the concern that I'd pull the knife out of my hand.
- SimpleIsGood229
Para cord lanyards, my friend!Pete1977 wrote:It's mainly due to the way I cut rope, especially when I was lobstering. I bend the rope to be cut back on itself, put the blade in the bight, and either push away from me with the edge outboard, or pull upwards with the edge turned up. When I'm going fast, or the boat was pitching, I tended to catch the rope in the choil and when wearing slippery gloves there was the concern that I'd pull the knife out of my hand.
God Bless Texas!
[RIGHT]Avatar courtesy of Dialex[/RIGHT]
Μολὼν λαβέ
2009 - Birth of the H-1 Spyderhawk! Thank you, Sal!
Μολὼν λαβέ
- The Deacon
To put things in a bit more perspective, I would describe the hollow grinds on both the older ATS-55 Rescues, and the Atlantic Salt, as very shallow. I can't see there being a singificant performance difference between them, and the flat saber grind on the Sprint Run VG-10 PE Rescue.
For the record, since it has been mentioned, the Mariner also waffled back and forth between hollow and flat saber grinds over the years.
