Serrated or Plain?
Whic do you prefer for EDC?
I prefer to carry a Serrated Blade.
30
31%
I prefer to carry a plain edge blade.
67
69%
Total votes: 97
MNJON
Serrated or Plain?
Post by MNJON »
That's the question! For an EDC, which would you buy if you only would carry one? I really like the Caly 3, plain edge. I wonder though, would I be better off for any reason with a Caly 3 SE?
SimpleIsGood229
Post by SimpleIsGood229 »
I think you need both, you know, for different specific things. If you could carry only one, generally speaking, I would go straight edge.
God Bless Texas!
[RIGHT]Avatar courtesy of Dialex[/RIGHT]
Μολὼν λαβέ
2009 - Birth of the H-1 Spyderhawk! Thank you, Sal!
Agent Starling
Post by Agent Starling »
I voted serrated but I carry and use both.
Agent Starling
"Too many was too many, but way too many was just right."
Post by The Deacon »
I'm lazy, I carry a PE blade, and avoid even any of those that cannot be easily sharpened on a flat stone. So there are no hawkbill, recurve, or reverse S blades in my EDC rotation. However I do keep a SE :spyder: in my car, in case a seat belt needs to be cut.
AUXCOM
Post by AUXCOM »
For me it's no question at all - Serrated. I've said it before - I am "Old School" Spyderco to me means serrated, stainless, and a hole! :)
" As Iron Sharpens Iron, So one man sharpens another" Proverbs 27:17
Chucula
Post by Chucula »
The Deacon wrote:I'm lazy, I carry a PE blade, and avoid even any of those that cannot be easily sharpened on a flat stone. So there are no hawkbill, recurve, or reverse S blades in my EDC rotation. However I do keep a SE :spyder: in my car, in case a seat belt needs to be cut.
Me too. I take maintenance into account when buying a knife, so I buy knives that are easily sharpened.
Lostification
Location: Sunset Beach - Haleiwa - Oahu - Hawaii - USA - Earth - Milky Way - 2ZS467 XD1 211 - Ä↔ôáÖºî±&#
Post by Lostification »
ditto
Para-Military - CPM S30V
Delica - VG-10
Tasman Salt - H1
dete
Post by dete »
serrated is very useful when what you cut is a variety of
random things.
also if you dont have time to sharpen the blade so oftenly.
Brad S.
Post by Brad S. »
I have never seen the usefulness of Serrated. Even when it comes to cutting seat belts and rope type things. I just keep my plain super sharp, and have never found anything I would have rather used a SE for.
Yes I own both.
Brad
cobrajoe
Post by cobrajoe »
Tricod wrote:I have never seen the usefulness of Serrated. Even when it comes to cutting seat belts and rope type things. I just keep my plain super sharp, and have never found anything I would have rather used a SE for.
Yes I own both.
Brad
I guess you answered my question before I asked, so I'm sure you've heard all the benefits before, but I thought I'd point out one virtue of a SE blade that some do not know.
You do not need to use a SE blade like a saw. I actually think that SE is better at straight push cutting (no slicing). But if you do slice, a SE blade will be much more aggressive and last a lot longer than a PE blade made out of a similar steel (I don't like to take sharpening breaks when cutting up boxes :p )
I voted SE, because there have been many, many times I wish I had a SE blade, but not very many times I wish I had a PE blade instead. I usualy carry both though :D
MEMBER OF THE INTERNATIONAL ORDER OF THE SPYDEREDGE
eastr
Post by eastr »
i voted plain but i carry and use both almost everyday there super can't go wrong with a caly3
"THE ROUGH RIDER”“FAR BETTER IT IS TO DARE MIGHTY THINGS..THAN TO TAKE RANK WITH THOSE POOR. TIMID SPIRITS WHO KNOW NEITHER VICTORY NOR DEFEAT.” THEODORE ROOSEVELT 1899
spyderco making mans oldest tool mans most advanced tool:spyder:
THE GREATSET POWER IS OFTEN SIMPLE PATIENECE
The only thing necessary for the triumph of evil is for good men to do nothing.
Piet.S
Post by Piet.S »
I like them both so I didn't vote.
All your knifelinks, http://www.knifelinksportal.com
spydutch
Post by spydutch »
Well................... :D :D
vampyrewolf
Post by vampyrewolf »
Properly sharpened a PE will go through just about anything. To get the same performance out of a SE you have to polish every single scallop.
Just sharpened one tonight for a buddy working in home construction. Highly polished 30deg bevel off a progression of 500grit, 800grit, spydie brown, spydie white, 2micron strop, 0.5micron strop... and a few strokes of spydie grey corners at 40deg on the edge. Won't shave but will go through just about anything he'll come across at work... only improvement I can make (with the steel in his knife) is knocking the 40deg edge down to 800grit.
We'll see in a week how it holds up to his use.
That polished 30deg with a rougher 40deg edge bevel will do 99% of the cutting I need. Even goes through seatbelt webbing like paper.
Coffee before Conciousness
bh49
Post by bh49 »
Exactly the same. PE in my pockets, SE in my car.
Woodwork
I do a fair amount of woodworking with my knives, so SE is not really an option. Or I should say, we use saws when we need SEs.
Left Hand Path
Post by Left Hand Path »
If I could only carry one - serrated edge. However, I like both, and I carry and use both just about every day.
-Nick
Join Today!
http://www.KnifeRights.org
Mr Blonde
Post by Mr Blonde »
I carry both, if forced I'd pick the PE. But only because I can make it either really coarse or smooth and polished. '
Wouter
Last website update: 11-30-2025 Instagram
malice4you
Post by malice4you »
Well for 8+ years, i've carried combo edge knives to have the best of both worlds. I like the more aggressive cutting edge of the SE and I like the generally finer control of the PE, and when mixed, you get both on most reasonably sized blades. On a smaller knife, a CE is less useful since you don't get enough of either edge to really do anything useful with either.
If I were forced to carry only one knife, and I couldn't carry a CE, I'd probably go with a SE, because I've only recently gotten a few decent fully SE blades to play with, and they are more useful than I thought. However, since I do have that choice, I'd still prefer a CE. Or a Dyad ;)
My EDC is a rescue 93 C14SBL, which has about a 3/4" PE section and then the rest is large, aggressive SE. IMO, this type of edge would be ideal for the most amount of cutting power and control in most blades (though I'd prefer a normal-sized spyderedge over the rescue's enlarged type).
In a perfect world where I wouldn't need to worry about being arrested, I'd carry 2 or 3 militarys, one SE, one PE, and one CE (plus probably a police, civilian, dyad, and a small knife or two to use around sheeple)
TK
Post by TK »
I prefer plain for its versatility and ease of sharpening. A few weeks ago I sold my Military/SE, because a serrated edge is not my piece of cake. It tends to rip more than to cut, though it is better on fibered materials. I do like the look of serrations better than plain, but once it is sharpend it lost its appearance.
Plain for me all the way.
"I always thought it would be great to have two wives."
"No! You're thinking of a man with two knives."
