decision prob. can spyderfans help?
NIGHTMARE77
Post by NIGHTMARE77 »
I posted this on bladeforums already, but figured I should post it on the "official" spyderco forums. Here's the problem, I have a delica 3 FRN comboedge that sits in a curio cabinet with the rest of my humble collection. Basically, it is new/unused. I just started an internship in an auto repair shop and need a good knife to cut some tough stuff like thick cardboard boxes and thick rubber hose. I wanted to get a new D4 comboedge, but my funds are limited as of now. I thought about taking the D3 out of my collection to use, and replace it someday with a D4 when I can afford to buy one. The only problem is, I can't decide whether to use the D3 as it is discontinued, and in my mind, somewhat more valuable. So, what do the spyderfans have to say? Should I just leave the D3 in my collection and wait to buy a D4 to use, or just take out the D3 and put it to good use? I also should mention that I want a good locking knife to carry when I go for walks around home here, as some of the backroads I walk are fairly desolate, and having a good lockblade on me provides piece of mind. I eagerly await your responses..
The CoPilot
Post by The CoPilot »
My advice to you comes from the lips of the man himself:
“Open, close, cut, clean, oil, cut, cut, cut... To a Spyderco, that is living. Letting it die in the box is to lose 75% of what we put into it." Sal Glesser
Take out the D3, use it, sharpen it, enjoy it!
><> The most important blood trail leads to the Cross <><
C09 CoPilots My Specialty
Integrity is Being Good Even if No One is WatchingTM
Looking for: C04 Executive plain edge, C09 CoPilot plain edge with brass liners and a G-2 marked blade
spyderdog
Post by spyderdog »
I say take it out of the case and use it. :) The D3 has a great point on it for piercing, and is lighter than the D4's since it doesn't have the liners. I don't think the collecting value of a D3 would ever skyrocket, but one never knows!
Do you have other Delicas that you're collecting for display? If not, definitely use it
whitefeather
Use it
Post by whitefeather »
The D3 begs to be used. The D3 was my first :spyder: Beware though, once you use it you will want more.
I don't beleive the D3 will ever be a super collectable but then again I use all of my Spydercos.
Enjoy.....and congrats on the new job
flyguy
Post by flyguy »
Is it a black handled FRN? (I assume?) Not really a collector's item... The new version is arguably better and not that different looking. There were way too many of them made to think it is going to be a special collector's item.
Use it! ;)
Jonny8642
Post by Jonny8642 »
I suggest using your D3. My second :spyder: was a D3 spyderedge, and it's the only knife I use on a constant bases. I have other :spyder: that are just as good if not better then the D3, but for over three years I've used me D3 for almost everything from personal security(although I don't recommend doing that), cutting open boxes to stripping wire. All in all it's a good all around knife and it must be used and congrats on the new job :D
Episteme
Post by Episteme »
I would also recommend that you use your D3. It's a darned good knife and it's so light you forget that it's on your person until you need it. As long as you use the knife to exclusivly cut things and not pry, scrape, screwdrive, etc., and you oil it and clean it daily, it will continue to look nice. I personally think that the D3 has some of the best ergonomics out there, and it's not even in the "top-tier" (most expensive) of the spyderco family. I love mine.
-Mike
"Two things fill the mind with ever new and increasing admiration and awe, the more often and steadily we reflect upon them: the starry heavens above me and the moral law within me." -Immanuel Kant
"I do not worry about what will happen; only what needs to be done". -Lucious Hunt, "The Village"
Simple Man
Post by Simple Man »
I second, er, third, uh, seventh...that opinion. The real value in the main run Endura/Delica series is through use. The old FRN clipped versions barely garner a higher price and they are long discontinued, yet still can be had with a only small bit of effort. I carry a numbered SS E4 with no concerns. Carry it with pride (but still get a D4 when you get a chance, you'll like it :D ).
Romans 8:31 ....If God is for us, who can be against us? - <><
The Spyderco hole is a rotating mechanical assembly of one part.
".....tractors don't have to look like Ferraris" -Sal
Raqudu
Post by Raqudu »
Use it! :)
The memories you build with this knife as you begin your new career will be worth more than any potential gain in monetary value.
Raqudu :D
Freedom is never a gift. It is the "pearl of great price" in anguish won.
[RIGHT]- The Theological Concept of Freedom[/RIGHT]
"Well, it's a nice soft night so I think I'll go and join me comrades and talk a little treason."
[RIGHT]- Michaleen Flynn (Barry Fitzgerald) in "The Quiet Man"[/RIGHT]
stonyman
Post by stonyman »
Use it! :D
Dr. Snubnose
Post by Dr. Snubnose »
Use it! For Sure!....Doc :D
Harry White
Post by Harry White »
not much collector value -- use it to death!
Users: SS Police PE, Delica 4 PE, Kopa Cocobolo, Blue Dodo SE, Yellow Pacific Salt PE, Micarta SPOT SE, Gray Calypso Jr, Temperance SE, Burgandy Jess Horn w/ZDP, UK Penknife, BB Delica 3 PE, Captain, CF Military w/BG-42, Lava, Caly3 SE, Para-Military SE, Manix CE, BB Para-Military SE, Delica 4 Wave, Ocelot CE, SpyderFly, Navigator II SE, Vagabond, D'Allara Drop Point CE, Black Assist I, Bug Set (and also: Sharpmaker, SS byrd Finch PE, Profile Set, byrd Firebyrd, Large Spyderpac, byrd Wings)
Michael Cook
Post by Michael Cook »
:spyder: Don't sell disco'd knives. You'll regret it later. :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
NIGHTMARE77
Thanks for all the feedback. I think I will take it out and put it to good use. I have a whole toolbox full of screwdrivers and pry bars at work, so I have no reason to use my spyderco for any of those tasks. I bought a delica 3 when they first came out and carried it for a few years until I lost it. It was a great knife, but I couldn't get it very sharp (used a stone freehand). Now I have a sharpmaker, so I think that my new delica will preform even better now that I have a proper sharpener for it.
